PDA
View Full Version : Transmissions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50
  1. shuttering trans
  2. Just another clunk (P to R back to P
  3. I have a (dumb) question about how the OD works.
  4. 30000 mile tranny change flush or pan drop
  5. Kansas City v. Norfolk
  6. Tran Fluid Change
  7. New Tranny Fluid or New Timing Chip?
  8. Coasting in Neutral with Manual Transmission
  9. Shift Kit, Torque converter, ect... What would be best??
  10. 1999 F150 AUTO TRANS HIGH REV.
  11. 2001 4R100 Failures - Stop Build
  12. Shift Kits and Warranty
  13. TRANSMISSION RELIABILITY
  14. Slush Box No More!!!
  15. Need to know what kind of tranny I have?
  16. "Slipping" feeling in tranny?
  17. Clutch Resevoire (How Full?)
  18. cruse control down shifting
  19. Transmission "lurching" during downshift
  20. Trans goin out??
  21. Trany. Shift Kit
  22. Drain Tube?
  23. 4 Wheel Low light not working?
  24. Intermittent delayed shifting out of 1st
  25. need tranny for '88 F150 4spd w/OD
  26. need tranny for '88 F150 4spd w/OD
  27. ELECTRONIC SHIFT ON FLY OR STICK
  28. Roaring from 0-15 mph
  29. What tranny fluid Should I use in my 5-speed???
  30. Troubled F 150 owner-please help
  31. TRANS & COMPUTER... HOW DO THEY WORK TOGETHER?
  32. 35-40 mph vibration
  33. transmission vent?
  34. Limp mode E4OD
  35. Transmission Failure
  36. Using the overdrive button...
  37. Routine Trans Service: Advice?
  38. Leaking Trans Fluid
  39. Tranny won't go into park.....
  40. How often does changing the tranny fluid fix problems?
  41. mlp sensor
  42. Transmission # 2 And a Rear End!
  43. Tranny Broke On Dyno!
  44. MY TRUCK IS SICK -E4OD-4.9L
  45. transmission
  46. Tranny about to go??
  47. Does the TC have a clutch?
  48. Trim Ring on Gearshift Lever keeps Coming off
  49. Outside Temperature Gauge used for Measuring Transmission Temperature
  50. Clutch quit this morning
  51. auto transmission loss in 3rd gear
  52. metal shavings
  53. IS Mobil 1 ATF rated 'Mercon V'?????
  54. Just installed Amsoil synthetic in tranny and transfer case, 97 manual
  55. Transmission slip, 3rd gear
  56. the street runner and this weekend trip
  57. Another Question on Tranny Fluid Changes
  58. Please Help-Tranny Problem
  59. Tranny Cracked
  60. Torque converter problems
  61. Anyone else Tranny Squeekin?
  62. grinding
  63. Transmission temperature
  64. To Eveolve or Stgnate?
  65. Trans. Flush No Mercon 5
  66. Trans Fluid Change vs. Flush
  67. 3.08 to a 4.10?
  68. Synthetic Tranny Fluid??
  69. Must be a problem with JET trans kit install, shifting too hard?
  70. TSB 99 14 sticker on 2001 auto SuperCrew
  71. Bigger Tires=Different Gear ratio?
  72. Brand of Mercon V
  73. Transmission slipping on 4R70W
  74. Any one familiar with the JET Electrical and Mechanical Shift Improvement Kit (4x4)?
  75. M5OD No 5th or reverse
  76. What size rear end?
  77. TRANNY FLUID
  78. Hubs not locking
  79. B&M Trany Fluid?
  80. OD
  81. new member needs trans help on 1999
  82. Make your own Gauge Pod
  83. Manual Transmission Warranty?
  84. Manual Trans Rough Shift To 2nd
  85. B&M Shift Kit, Same As ****ft Plus??
  86. Towing in OD
  87. Rear diff, going to switch gears, need help
  88. Overdrive light blinking????
  89. 97 vs 00 Manual Trans
  90. Someone Explain Gear Ratio Pro's and Cons
  91. Magnet in Tranny pan?
  92. Changing tranny fluid
  93. Transmission Troubles
  94. O/D Disabled Automatically
  95. Rough Shift to Second Gear
  96. B&M Shift Improvement Kit
  97. sick tranny?
  98. vibration
  99. No REVERSE when engine is hot
  100. How to determine axle ratio on used F150
  101. Tranny rolls back in drive on inclines
  102. Why does my 83 bronco shift better then my 98 f250?
  103. Hard shift into 2nd
  104. C4 transmission died suddenly??
  105. Advice on B&M Shiftplus please?
  106. "Chirping" sound in 2nd gear 4R70W
  107. Transmission gear ratios?
  108. Redline Oil
  109. Torque Conveter Drain Plug Torque?
  110. Transmission ID?
  111. Engine braking
  112. B&M Shift Kit Installed
  113. Hard upshifts with E40D
  114. E40D Oil Change & Filter How Much?
  115. help re. driving in O.D.???
  116. 4R70W Pressure Plug Thread Size??
  117. Where can I buy trans. temp guage?
  118. help re. transmission type for a 1999 f150????
  119. 5 spd manual grinds between 1 and 2nd gear?
  120. 4x4 Shifting problems???
  121. Can you swap in a heavy duty transmission?
  122. Transmission hangs in 2nd gear
  123. 3.08 to 3.55 swap
  124. Powerflush affecting mileage?
  125. Tranny Cooler Installation
  126. 4R70W and Temp Gauge
  127. tranny swapping
  128. Very Hard Shifing from drive to reverse
  129. normal tranny temp
  130. Clutch problem
  131. Say good-bye to manual transmissions?
  132. 4r70w or e4od
  133. anyone else got THIS problem???
  134. anyone else got THIS problem???
  135. I JUST DON'T GET IT........
  136. Shiftplus long term use
  137. OVERDRIVE RATIO
  138. 3.08 to 3.55
  139. Manual tranny
  140. Is it worth it to replace auto trans fluid with synth?
  141. 4 X 4 F - up
  142. Rear Axle Ratios
  143. Trans Temp Gauge Install
  144. Auto Trans Temperature
  145. Gear selector adjustment?
  146. Tranny Weight
  147. tranny shutter
  148. Firmer shifts for auto tranny
  149. fluid leaking from differential
  150. reset shift points by computer...how-to???
  151. banks transcommand / ottomind
  152. trans code U....?????
  153. Slight "shudder" at take off.
  154. Underbody rust on new F150...
  155. High Stall Speed Torque Convertors
  156. Bang Shifting E4OD
  157. 5speed short throw kit
  158. XL 4X2 5-speeds can have a tach
  159. shifting suggestions
  160. M50D
  161. Was the the 4R70W designed for a '71 Pinto
  162. Blown or Blown Tranny
  163. Can computer learn new OD shift?
  164. Anyone have fluid change photos?
  165. Vibration at 40mph
  166. Transmission acting funny
  167. 5-speed squeak?
  168. Will a '97 E4OD bold in place of a '89 E4OD?
  169. auxiliary trans filter
  170. Transmission Leak turns into a Vibration when fix'ed!
  171. Transmission servo problem......overdrive light was flashing on and off
  172. Will someone tell me what the rear axle ratios are and what they do?
  173. E4OD and 4R70W return line fittings - which?
  174. Trans fluid flush or drain?
  175. re: Torque Conv. drain
  176. Transmission question
  177. Whistling noise in sync with RPM
  178. Shift Kit, Shift Improvement Kit, help?
  179. Transco Interceptor
  180. 5.4 automatic trans
  181. Slush-Box of a Transmission…
  182. Attn: Factory Tech------------------------------>
  183. 4.2L w/Auto recalibration available yet?
  184. Towing - Need a Tranny Cooler???
  185. E40D
  186. tranny pan with drain plug $35
  187. OD cancel light
  188. Installed B&M ShiftPlus+ kit
  189. Auto tranny hangs in 2nd when cold
  190. Mercon III?
  191. Should I Replace the Factory Tranny Cooler??
  192. 5 Speed 4.2 Problems
  193. TRANNY FIX
  194. What is causing this?
  195. grinding from 1st gear to 2nd gear pm 4.2L
  196. Replaced transmission by Ford
  197. help!!!!!
  198. Trans shudder/chatter
  199. auto transmission fail at 32,000 miles
  200. clutch free shifting?
  201. grinding
  202. trans fluid mini chg-t'ween Reg changes
  203. Warranty Effects…
  204. 98 E40D Tranny Fluid Change
  205. Superchip and Factory Shifting
  206. Too high RPM b-4 shifting 1st to 2d, 4.6 w/3.55LS '99 model
  207. Is this a problem, if so need help!!!!!!
  208. Cluncking Found
  209. Questions about synth. oil in 5-speed
  210. THE "FREAK" FINALLY ORDERED IT!
  211. 4x4 - Electronic or Manual Shift?
  212. Plastic Plug
  213. Torque Convertor Chatter
  214. 96 F150 4x4 4.9L ; have 5spd tranny w/granny, want normal 5spd
  215. Machine Flush of Fluid
  216. Aftermarket clutches
  217. Speedo Gear for 4.56
  218. speedo recalibration for 99s
  219. I REALLY NEED HELP WITH THIS B&M SHIFTPLUS
  220. water in transmission?
  221. M5ODTorque Specs
  222. What is that downshift clunk noise?
  223. Green-tagged Y2K Transmissions
  224. Overdrive "off" upon start-up?
  225. Shift harder??
  226. Truck go'z reverse in neutral
  227. Vague B&M instructions
  228. Part Number needed...
  229. B&M Shifter Plus For 93f-150
  230. Experiences with new auto behind 5.4 in '00s?
  231. Problem with clutch squeaking
  232. F-150 5 spd manual - experiences?
  233. Vehical speed sensor ?
  234. 93 F150 4x4 4sp granny - Change to 5 Speed?
  235. What Tranny
  236. Air in slave cylinder
  237. warrenty problems
  238. Good tranny rebuilder
  239. At how many rpm's do you switch gears?
  240. Tranmission noise
  241. Tranny temp gauge
  242. Transmission Coolers
  243. Overdrive/Towing?
  244. ? for anyone w/ B&M electronic shift
  245. Tranny temp gauge installation
  246. Leaks
  247. Shift Linkage
  248. Shift Knobs
  249. how to drain the torque conv. on a 99 4.6 ??
  250. Transmission Whistle ?
