View Full Version : Transmissions
- might be, might not be transmission
- 2/3 upshift question
- Manual to Auto Conversion with 300 Inline 6?
- What kind of oil ???
- Fluid change and flush = filter change?
- Tranny Failure Tonight.
- Trans. Temp Gauge wiring... sender??
- WLF, Tiger, You guys saved me $1,000!!!
- Redline ATF
- Could this fix 1st gear shifting problems ????
- Foreign object in transmission pan
- Transmission fluid
- Shuddering corrected on 2002 SC
- Noise from the trans.
- ttt
- Tranny Lookup & Gears
- shift problem e40d trans
- Dana vs Ford
- Manual 4-speed trannie leak
- Shudder from stop... only when turning
- Do I need new Trans?
- Transmission Valve Option
- Vibration problem on lowered F150
- E4OD won't shift into 3rd gear, please help.
- Return LIne
- % speed Shifting
- Tranny o.d. light blinking
- Question About Overdrive
- Screw ATF change
- Passing Gear Adjustment
- whats the best gearing ratio or size?
- Ok, new Q: How much $ to replace 2-3 syncro?
- 5 to 4 speed conversions HELP
- trans fluid leak at line into radiator?
- it's almost here from hurst
- Differences, 4R70w & 4R100?
- 5 speed grinding from 2nd to 3rd?
- Speedo cable
- 2003 not shifting at high rpms
- Total flush on transmission?
- Transgo install, I think I broke something...
- 4WD switch location-ever hit 4WD when going for fan?
- Need help from tranny gurus
- Tranny noise...getting worse too.
- Stuck in 4 wheel drive
- AMSOIL ATF supplier's?
- Shifts hard
- Tranny jumping out of gear then slaming back in
- any techs have info on tranny?
- Broke balance ring on driveshaft!!!
- Nasty Grinding Please Help!
- How to eliminate Torque Converter Lockup
- what tranny do i have
- Torque convertor lockup (3rd & 4th) gear
- Please help diagnose this problem.
- Tow package?
- Low Hum Noise
- tranny cooler (question)
- HELP! Did I mess up??? (kinda long)
- Type of tranny my 2001 F-150 4X4 has?
- About the SHUDDDDDEEEERRR
- 2001 4WD SuperCrew with BAD SHUTTERING
- Tranny Fluid
- '89 F-150 - AOD Shuddering heavilly in 1st
- put 01 expy in shop this morning, tell me what you think shudder is
- Manual Tranny Knocking coming out of 1st
- 88 AOD downshift problems
- 4R70W valve body torque spec.
- I found it, manual shifting of electronic trans
- 2001 F150 Transmission problems
- Transmission Shudder
- Stripped Threads
- 2001 F150 high RPM squeal
- help on f150 5-speed
- '86 4spd AOD swpped to '70 C4??
- F-250 6-spped transmission in F-150
- Get up and go in 3rd
- uphill probs
- Fluid change intervals
- best tranny
- O/D Light blinking
- 1990 Ford F250 E4 od tranny
- 1997 F150 4x4 5.4 Tritan
- 5 Questions...
- My 9.75 Went Ka-boom!!!!!!
- Hard shifting in a Mountaineer
- Hard 4R70W upshift 1st to 2nd
- 5th gear hard throttle rattle
- High HP with 4RW70??
- how much.....
- VSS Help .... switching rear ends!!!!
- whats the dealio
- E4OD Swap question
- Factory Tech Website?
- 1st Gear Shift
- Factory Tech valve body
- 4R100 Cooler Lines
- Normal Driveline Noise
- Synthetic 10W-30 in 5-Speed -- Ideas?
- Tranny HELP 1984 please
- Manual Tranny
- Transfer case
- won't shift to park
- Bad Torque Converter Killing Tranny
- Putting a B&M shift kit in my 1997 f-150 4x4 need help
- H9
- 2003 150screw Lariat
- Want to add a Transmission Cooler
- Banks Transcommand?
- Slave cylinder woes
- 5spd troubles again.. Wont go into any gear.
- Temperature Gauge Installs Voids Warranty ?
- Rear Seal On Automatic Tran.
- Trans. slipping
- Tranny Gurus or Someone Help Please
- 4R70W build up
- 4R70W Fluid Change
- Tranny fluid level HELP
- E40d Will Not Go From 2nd To 3rd??
- After much searching, I think I've found the 4r70w transmission for my truck.
- AOD Shifting Problems
- popping at low speeds
- help. transmission/transfer case dead?
- For those with FTVB
- OD light blinking, please help
- trns leak
- trns leak
- Question for Neal
- What can My OEM tranny take tq wise?
- Transmission question for Neal
- Strange 1-2 shift...
- Transmission manufacturing date
- new noises from 5 speed tranny
- Expedition: Manual transmission
- Trailer effect w/o trailer
- slippage!!!!!
- Transmission Temp Gauge Wiring
- E4AOD problem
- Manual Transmission Swap
- Flex Plate or Converter for Lightning swap
- 5-Speed Shifter Question
- A question for Mark Kovalsky, Factory tech or anyone who can help
- 4r100 modify
- Aftermarket Trans. Pan
- Mark VIII torque converter in a F150?
- Factory Tech VB HELP! PLEASE!
- Repair Bill....
- Ideas about trans problems? E4OD
- just got new 4.10s.... plus a ticket :(
- Update on 2000+ 3rd-2nd downshift Clunk
- 5 Spd Manual - Warpage?
- manual transmission F150 1990 shifting problems.
- 5Spd better shifting after lube change
- E4OD To AOD Tranny change
- Aamco MerconV Syn blend
- How many quarts of ATF?
- Hurst Shifter
- Tranny problems, please help!!
- 98' E4OD Exped. Towing Durability?
- tranny swap
- E4OD harsh engagements & shifts
- first impressions FT valvebody
- Tranny fluid warm up (gauge question)
- Clutch problems
- Trans. drain plug and gauge install
- Hard shift from 2nd to 3rd
- Won't upshift while towing
- Speedo Gear chip
- ATF level
- tranny flush?
- Bearing pieces in tranny pan!
- synthetic replacement for mercon v
- Change tranny fluid at home???
- How do I indentify the tranny I have????
- Clutch Question
- tranny oil
- good 6 speed trany ????
- Squeek/Clicking while Accelerating
- F150 1998 transmission + Flywheel trouble
- Autometer Gauge Pods
- I was told by two transmission shops NOT to change my transmission fluid. What Gives?
- aod to c6 swap info
- manual transmission swap
- grinding
- Opinions on Tranny Temps
- How do you adjust transmission linkage
- Diference Between 4r70w And Aode
- 46,000 miles
- 5 Speed Upgrade
- Shuddering / Bucking problem
- Is expy factory tow pkg adequate?
- Has anyone tried to put a Ratchet shifter in their truck?
- Gear indicator slipage
- Who's right? (E40D question)
- 4R70W question
- 4R70W Tranny Question
- tranny slips in and out of gear
- Is is possible to disable automatic 4-wheel drive???
- Need to Know Ratio of 1st. gear in 4R70W
- Transmission durability
- Trans-Go Shift Kit - with or without video tape
- Truck rolls in Park, truck rolls backward in Drive
- 6spd manual/clutch
- WTF is going on
- Tranny slipping?
- Shift Improver woes
- OD...on??...off??
- Tranny change tip
- tightening the driveshaft... more torque??
- F150 Auto Trans Problem
- What tranny is in my 99 expy and what shift kit do i buy?
- Checking fluid level
- Transmission Torque spec HELP Please
- To change or not to change...
- Changed tires size...? about the # of teeth in spedo gear
- F150 Transmission Troubles
- 2002 Transoil change ?
- Sea Foam
- c6 tail shaft
- 2003 F250 V8 6.0l tranny problem
- Transmission model type
- Lightning Monster Box
- 2001 shifting issue
- clunking rear end? solved
- when to service transfer case.
- nO OVERDRIVE
- Trans service
- Factory Tech VB
- Will Bigger Tires = Transmission Issues
- ATF change w/unsure sevice record?
- Help with vibration diagnosis
- Please help ASAP! A4LD trans not going into gear! Must fix SOON!
- Man 5 spd shift feel Update #1
- Think my E40D just blew a seal. Help
- No passing gear?
- What are the manual tranny sensors?
- Faster truck!!!
- Jumping Transmission
- Trans-Go Shift Kits
- Mounting a trans temp gauge
- 15,000 mile transmission service/dealer gouging
- Wont go into any gear.....
- Shift Kits???
- F-150 Will not go into 4h and 4L?
- Trans Range Selector
- aftermarket tranny pans?
- Flashing OD Light
