Tranny Cooler Installation
Old May 17, 2000 | 03:58 PM
Brewby's Avatar
Question Tranny Cooler Installation
I am in the process of installing an aftermarket(Hayden)tranny cooler on my 99
F-150 and was wondering if it really matters where you tap into the return line? Do you have to tap into near the radiator? I was going to use fittings instead of cutting my return line, but I can't seem to find anyone who carries them for a 99. I picked up some for a 97 and they wouldn't fit.
Old May 21, 2000 | 10:07 PM
Tiger's Avatar
Post
Same problem here. I've spent about 3 months looking for fittings and finally found male fittings at NAPA but could not find or get even from NAPA the female. But I did find a double female coupler which I installed on a male to make a female. Haven't done the install yet due to lack of time but will complete the job in a week or so. I don't see any reason this shouldn't work. I couldn't bring myself to cut a line either.
When looking for fittings make sure you ask for Inverted Flare types. I found the double female coupler at Trak Auto.
Good Luck!
99, XL, SC, SB, auto, 4.6L, 255x70R16, 3.55LS, 2wd, Med Tor, Dk Grph, Raider LoRider Tonneau, Valley class III hitch, bed mat.
Computer Code YBQ3
More to come!
http://home.att.net/~neilwood.pe/wsb...ome.html-.html
[This message has been edited by Tiger (edited 05-21-2000).]
Old May 23, 2000 | 12:49 AM
Brewby's Avatar
Post
Thanks Tiger for the input. Since I couldn't find the fittings I needed, I did do the dreaded cut and tapped into my return line. Everything seems to be working after fixing a small leak.
By the way that is a nice truck you have! It is nice to see such pride in ownership.
99 XLT SC 4X4, 4.6 Auto, Red/Silver, Superchip, K&N filter, TFX Kat Back,
