Brand of Mercon V
Hey guys, What type/brand of Mercon V are all of you putting in these 4r70W Trannies???
I need to do mine asap for a road trip
Thanks in advance
Todd
1998 F-150 SC Flareside 4.6 Wht/Grey Auto
Additions: Line-X 8-31-99
4.10:1 Pro Auburn, Custom made cold air induction system, Flowmaster exhaust, N2O (when needed)
Epic Lakota Chrome wheels and 285-75-16 Bridgestone Dueler AT (no lift and no rubbing at all) tires.
Thanks in advance
Todd
I found at Pep Boys Valvoline DuraBlend Mercon V for $2.50/qt. Any opinions on this trans fluid?
Todd
Todd
Mark, where did you get this information from? I have put 14,000 miles on Mercon V in my 97 e40d. I did notice it didn't shift as smooth as the Mercon. The top mechanic at a local dealership told me that Mercon V is better for it. I to have the AAMCO Mercon V.
I got my information from a Ford TSB, 98-8-8. It says not to use Mercon V in the E4OD or the 4R100. It is good to use in the 4R70W.
From other contacts I have, I have been told that Mercon V has caused high wear in E4OD and 4R100 transmissions. You won't see a problem in 14,000 miles, but I'll bet you will wear it out sooner than if you used the correct fluid.
