Trany. Shift Kit
Old Aug 25, 2000 | 02:03 PM
mearnh's Avatar
Question Trany. Shift Kit
Can anybody recomend a good trany shift kit?
I hope to change out my 3.08 for a set of 3.55's soon and I'm thinking that it would be a good time to get the trany kit.
all comments/recomendations are welcome,
mearnh
1999 Reg cab flare side
4.2L V-6 w/3.08 rear end
Toreador Red
Bone stock for now,
air silencer removed...don't know that this helped any.
tinted windows...don't make it go any faster.
K&N filter...maybe it breaths better, I can't tell.
Old Aug 26, 2000 | 10:43 AM
T Ellenberger's Avatar
Post
I and a few others have installed the TransGo Shift Kit. I had never been further that the filter in an automatic trans before so it was an experience. Had to drill a couple of holes in the valve body and change a few valves and springs. Kit came with a video so I put my VCR and an old TV in the garage and used the rewind button as much as my tools.
Shifts faster and firmer between shifts. If I get on the pedal it shifts real firm. The kit was ordered from Summit.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks
Old Aug 31, 2000 | 08:43 AM
Robs4X4's Avatar
Cool
I installed my B&M Light Truck Transpack, P.N. 10057, and I love it. Took me like 4 hours to install, not too bad. Might have gone quicker if I had remembered to put the filter on the first time. Oh well, but the instructions in the kit were great, and the quality of the shifts now is excellent. Just my two cents, and I also purchased my kit from Summit Racing.
Rob
1997 F150 XLT Ext. Cab, Green, 4.6 v8, 4x4, A/EOD, 3.55, K&N w/Low-Buck Airbox Modification, Splitfire Triple Platinum Plugs, Bedliner, 265/75/16 Dunlop Radial Rover RV's, Soft Tonneau, Door Cracks (fixed for now I hope...)Well Nothing lasts forever, Driver Side Cracked, Again...
