- 4th time in the shop in 3 months.
- Just wanted to thank everyone
- E4OD Transmission Problem
- 2001 5-speed TSB's...
- Vibration when let off the gas
- Great article on 4r70w.
- used 4r70w
- What trans is in this truck?
- Tranny trouble
- Hurst 5-speed
- Truck stutters in 4-wheel drive
- I found a great deal on a new 4r70w but.......
- A4OD Fluid Types
- Speedometer gear?
- Shifting Problem/question? Please Help!
- E4OD Selenoid Buzzing - B&M Shiftplus
- Strange Shudder
- Shifting in cold wheater
- Speedo
- ATF & Filter Change
- tire change
- 4R70 Swap
- 4R70W help, referred to Mark Kovalsky for help
- Axle Identification
- What could be wrong with a Torque Convertor.
- Popping Noise Driving me Nuts
- Squeaky clutch pedal
- ATF just trickles.....?
- Auto downshift on lite accel.
- Shifting Problem
- Clutch Problem
- 2001 transmission
- Fluid change
- Hard Down shift
- Tranny service on 98 Ranger Auto OD
- U-Joint
- Help, funny noise when I start driving
- 98 E40D Shudder into overdrive
- questions about 4r70w
- Mark or Factory Tech TQ converter question
- Tranny leak around a rubber plug! HELP
- Tranny cooler I got
- Atf
- Changing 5 spd tranny fluid.
- trans temp gauge
- Anyone mess with shift improvers...
- Loose rear end?
- Makes me Frustrated!
- Manual Tranny Swap
- help please!!
- E40D to C-6
- What should I do?
- Trans - coolers
- Need some advice
- another fluid change question
- fluid change
- Truck goes to Hacklers Tranny shop....
- Neal, Factory Tech, or any other 4R70W expert??? Temp gauge problem
- torque converter
- Magnet
- Towing ???
- Transmission pans for the 4R70
- 2004 Sealed Transmission
- which lim. slip?
- maunal to auto swap
- E40D questions
- 4r100 build up for 750 hp fly.
- no O/D light no O/D
- Transmission Fluid
- Tail shaft length
- tranny clunk
- E4OD Fluid Change Recommendations?
- Transmission fluid
- Well its gone
- plug-in shift kits?
- Strange behavior in OD
- How you doing fellas! This site is awesome!! Please reply with some help.
- Questions about 4R70
- Question from a new member
- how do the reman 4R100's hold up?
- fix for 5spd tow rating
- plastic plug in 5speed
- Shift Kits
- please help the dumb ford mechanic
- Valve body for 4R70W??
- need greg evans valve body for '99 L
- 4WD will not disengage
- Had an irritating experience
- 4R70W Pan Bolt
- My transfer case (What Happened to it)
- Transmission Gasket
- O/D Light Flashing
- Strange Noise at 50 MPH
- Terrible grating noise when starting up
- 96 Ford F150 Shudder
- Front Axle Question
- Auto Tranny problems in 1999 F-150
- no manual trans in 2004?
- Deep Trans Pan from PML (yourcovers.com)
- Question on New 4R75E Auto. Trans.
- Tranny Prob
- How often for tranny flushes?
- Who's done the tailshaft replacement?
- ?s about shift kit for 984x4
- Well, I Installed The TransGo S/K...
- Flush machine or conventional drain?
- Need Help Fast
- Clutch Pedal Question
- How many quarts???
- Overdrive light flash?????
- 4R70W Drain Plug Install
- 4R70W performance buildup articles!
- $1200-$1700 for a clutch??
- Calling Mark K- AODE help
- Leak after highway driving
- Noise only when accerlating
- Flash Update PCM
- Torque Specs
- Where to buy VSS gear??
- 2004 4R75E tranny??
- Factory Tech
- Temp gauge--In Pan or In Line???
- Resetting Computer
- Transmission Harsh Shifting
- 2004 Edmunds review
- Slave cylinder
- e4od any good???
- Torque Converter Drain
- 4x4 Low Question
- What Happened To My Transfer Case?
- Possible tranny problem?
- Tranny slips from 4HI to AWD occassionally
- Mark K. Re: 4R100 a/t
- Leaky Tranny
- Trick Flow Trans Pan
- Shift Lever Rattle
- the Mustangs have them why cant we
- 2003 F150 with 4.6 Engine
- I can't get my truck out of park
- Transmission / Rear End Shudder From Stop
- F150 Whine
- clutch problems?!
- transmission issues
- Ok the Shimmy in my AODE is back!
- Thanks
- 4WD Lockout
- Older Ford engine swap question
- Temp Gauge Installed
- Where can I buy the Sonnax valves from?
- Need some info
- 4r70w shift shudder
- What trans do I have?
- How many quarts of fluid does the E4od hold?
- transgo shift kit install ?'s (help)
- Transgo Kit arrived! All trans gurus please look inside!
- Shifter Rattle in 5th gear
- plastic plug thingie in trans pan, needed?
- Super Hard Shifting from 1st to 2nd
- OK,just ordered the TRansgo shift Kit any info?
- Downshifting 4R70W on Long/Steep Grades...Damaging ???
- Mazda 5 speed - in other trucks?
- Can't fix it?!
- Transmission Temperature Gauge
- What the difference between reprogramm kit and shift kit
- OD Cancel then Slams into Third
- O/D always off unless......
- 5 Speed Cost?????
- PFYC Tranny Cooler
- New Transgo Shift Kit Installed!!
- Line Direction ?
- Mike K. Re: 4R100
- Tranny shudder
- 4WD help!!!!
- Clutch Safety Switch for Starter
- New Valve Body In A 4R70W ?
- fluid usage?
- Tranny cooler...
- Any correalation between tire size and the infamous Ford clunk????
- 6th Transmission
- Loud thump when tranny shifts sometimes
- In-Line Transmission Filter
- Bolt up
- O/D light flashing
- Help with Transgo shift kit
- and...
- Slight Knock
- Hepcat Helm!
- Road noise when hubs are locked in.
- Over-Rev problem??
- Shudder in the transmission
- Transfer Case Extension Housing Seal
- 5.4 Lightning with 4R70
- What Tranny Does My Expo Have ?
- Leaking fluid from tranny pan . . .
- Valve body removal
- Will Shift Kit Make Truck Faster??
- auxiliary transmissions
- Trans change
- Transmissions
- Checking a/t fluid
- Transmission Slipping
- Speedo quit in my 97 4.6 SC
- Transmission Shop in North Texas?
- Trans Problem?
- Which spline do I have?
- What trans. do I have?
- Tranny is acting funny
- Synthetic trans fluid?
- 1st to 2nd knob come off . new one?
- When to change transmission oil and front and rear differentials?
- how to tell the difference
- Just quoted $2500 for new tranny...is that too high?
- blew up tranny just to see it die...
- EARLY transmission problems
- Driveline Vibration
- Mercon V OK in a 99 250LD E40D tranny?
- Torque ratings of 4r70w and 4r100 trannies?
- power loss & shutter or virbation
- How Much For TransGo Shift Kit??
- vibration fixed
- Temp Probe Placement
- "TCIL" flashing again.
- EMERGENCY!! HELP!! 4WD folks!!
- Shift Kit Questions
- Valve Body Install - HELP!!!
- Buzzing Noise Behind Dash
- Line Size
- 4r100
- vss gear
- Just put my transgo shift kit in
- PA Valve Body
- odometer? un-hook?
- No overdrive on cold mornings
- Transmission problem?
- Harsh Shifting
- what kind of tranny oil in 5-speed
- What lift Kit?
- In a rental again
- transmission coolers?
- Change Tranny lube or rear diff
- Flush ? - Opinions
- trans not engaging
- What happened to my trans?
- Fluid Change @95k
- Fluid Change @95k
- Valve body
- The Little Rubber Thing
- Flushing Cooler Lines
- what caused this?
- New Ford Tranny's
