Trans. Flush No Mercon 5
I have a 97 F150 with the 4R70W transmission.I had dropped the transmission pan last October and changed the filter and just the fluid in the pan.The reason I did this was because of the vibration when going in to overdrive.Well it corrected it but it came back so I decided to have the transmission flushed. I took it to a Valvoline Instant oil change center and they would not refill with Mercon 5, they said they can only refill with what the vehicle originally came with.So I got the Dexron/MerconIII.Trans now works fine.I know some of you have switched to Mercon V,are you sure you can do that without damaging the transmission?
Dennis
Dennis
