View Full Version : Transmissions
- Trans Cooler
- down shifts by itself
- Correct Speed
- Trans shifts itself out of 4wd...
- rumble-strip like vibration. Tranny?
- Factory Tech and Mobil 1 ATF
- How Do You Determine Gear Ratio?
- my E4OD and a huge headache!
- Backup light switch
- Is factory fluid synthetid
- Explorer tranny..what is wrong?
- Best manual tranny oil & diff fluid?
- Torque Converter?
- TransGo vs Baumann vs Level 10
- Clutch chatter.
- 97 F-150 Transmission fail
- Can anyone explain the advantage of Sonnex or Baumann Valves?
- What tranny do I have?
- Transmission shudder/thud and slip-yoke
- Can someone sort out confusing Mercon types?
- Have you done this?
- E4OD maintanance @ 50K miles.
- Shifting Auto. like a Manual??
- Rattling clank in reverse
- Super Duty Transmission
- Gear Ratio?
- What Do Baumann Valves Do To Improve Shifts?
- Tranny Shifting
- look what I found in my tranny????
- Tranny/tire Problems
- 4r70w or 4r100?
- What is that rubber plug on my tranny?
- Problem 4X4 engages by itself
- E4od Transmission
- Questions on 4R70W Shift Kit
- slip`s going into 2nd
- E4OD and 302?
- Trans life
- my opinion
- 4R70W Whine at 12,000 Miles - HELP
- Am I Halucinating?
- Where's my trans. fluid going?
- trans vibration
- Shift kit ideas anyone?
- Tranny Fluid
- Trans Overdrive
- Trans Help
- Not Tranny but just curious....
- 1 - 2 clunk anyone?
- Can't get into 1st gear at stop.
- A question for Factory Tech
- 4.6 5spd shifter?
- which tranny do I have?
- Transmission noise under full throttle
- B&M pan won't clear crossmember
- Got the Diablo Sport, now what (Diablo Valve body kit or what?)
- Transgo Install "Settings"?
- general question about a ford tranny.
- can i swap transmissions from an automatic to a manual?
- OD Light Blinking?? 99 5.4 Lariat
- Always looks dirty?
- transmission
- Need copy of Tailshaft TSB
- Overdrive/Convertor
- Driveline vibrations
- Factory_Tech where is thw TQ drain???
- warranty riembersment for dealer?????
- Ticking noise in 5th gear...
- what model tranny do i have?
- Tailshaft Problems, Help!
- Changed my T-Fluid/Did I miss something?
- I'm stupid...
- Transmission Problems, Look no further!!!
- Lining up drain plug with hole in torque converter.
- Average Clutch Life??
- Won't come out of second...
- New Machine Drains Clutch Packs and Torque Converter Too!!
- help me figure this out
- There's a drain plug on the Torque Converter
- Shift Kit?
- Poor transmission performance in Screw
- Trans Upgrade
- speedo twitch
- 4-High VERY tight
- Need technical advice
- Trans oil
- How much toque and HP can it take ???
- Lightning tranny on 4.6L?
- 4R70W Shift Kit
- New Tranny?
- Cost To Install TransGo Shift Kit??!!!
- Overfill
- Dipstick leak
- 82 trannie
- Help with tranny temp sender placement
- LEVEL 10 HYDRO vs TRANSGO SHIFT
- Does your 5 speed do this?
- Level 10 Hydro System
- Transmission "Thud"
- New Tranny on the way
- Calling Factory_Tech
- trans problem
- Local Ford Dealer is Clueless!!`
- Ext. Warrenty - How Much
- How-to article on changing fluid
- Can you tell by looking what tranny you have on a 2001 F150 ?
- Manual Transmission Conversion
- Need advice with tranny replacement
- Hydraulic line disconnect
- Power shifting
- Possible tranny upgrades need so answers...
- Recommend best automatic mods??!!
- 4r70w Erratic Shifting
- How Tough to rebuild E4OD
- I got Screwed! - Manual Tranny Towing Question
- 5 spd. high performance replacement
- Filter Change Question
- O/D Light Blinking
- Downshift Shudder
- Trans cooler line- flow direction?
- 99 F150
- transmission seizing engine
- what is this sound??
- Just changed my transmission fluid....
- Calling Factory Tech E4OD Noise
- '98 4.6L revs too high at W.O.T.
- C4 Tailshaft
- Clunking into Second Gear
- anti slip
- trans cooler line kinked- solutions for fix...help
- Tanny squeals
- Did for change the recommanded fluid for the 4r100?
- Transmission question
- transmissions
- short throw shifter for the 5 speed?
- 5 sp. Shifter Replacement
- Factory Tech Shift Kit ='s Chip Reburn???
- Mounting trans cooler??
- Auto-tranny problems - What is Job 1?
- HELP!! Truck stalls in Reverse
- AODE died- swap or rebuild
- Torque Converter related to chip?
- Will AOE40D run w/o ECM
- overdrive.
- Failuer code P09
- HELP!!! Need transmission advice.
- new truck transmission
- Shifting Firmness
- Late Shift
- Stuck in 4 wheel drive!
- Speedometer change with 30" tires
- Looking for TransGo Shift Kit Part #
- who gets 4R100 trans?
- Tranny ID question
- O.D. Trans. has shifting problem
- 1992 & 1993 F-Series Automatics ???
- New transmission
- What's Ford's official position regarding phasing-out manual transmissions?
- how do you know what trans you have
- Newbie.. Ford make 2 autos?
- Well I Finally Figured Out Why My Overdrive Was Working Only Sometimes!!!!!!
- zf transmission
- Hooking digital speedo to old tranny
- Which speedo gear?
- Can't Brake Stand!!!
- Auto Overdrive Clunk after FQR Change
- Better manual trans fluid?
- Auto Trans Linkage
- 98 E4OD 4 Sale
- AOD slipping?
- Auto Tranny Likes
- will a new speedo gear really help??
- Transgo, go, go
- transmission or Clutch?
- shift linkage adjustment
- all 5-speed users
- whats the ratio for all the gears in a 5 speed?
- hard stop thumping
- Stuck in Park! Again! How do I defeat interlock?
- Speedometer not working.
- Installed "Factory Tech" Valve Body.
- Which tranny do I have?
- ok
- 4X4 sticking and then fine.. WTH??
- No new tranny for me
- ok thanks
- B&M transpack for 4R70W?
- Transgo Kit
- Rear of Transmission Leaking??
- HP loss from flywheel to tires
- how much hp can the f-150 4.6l tran hold
- Precision Industries torque converter......
- metal shavings
- A bump as it goes into 2nd gear.
- 65K tranny shot!!!!!! What the heck!
- Where is the serpentine adjustment?
- Factory Tech, Anybody? Asking again
- i need a new clutch
- Fluid change
- Transgo! Shift Kit Install - 4R100
- Hydrolic clutch bleeding
- ATTN: GAH...questions
- Torque Convert Questions
- whining noise when iout of gear
- Getting Ready to Install Transgo Kit - 4R100
- ford460 fit a 351 tranny?
- strange noise
- Level 10 kit for durability? Neal?
- Attn. Factory_Tech
- Shift Kit's or other mod's and Towing
- strange 3-2 downshift?
- Anybody installed a Tremec T-5?
- 2000 5 spd is junk
- Changed out trans fluid
- Stalls when put in reverse, what could it be?
- Force Shifts on Automatic?
- Whats this sound?
- Hey Guys? Check this out!! Shudder fix?
- Stacked Plate Vs. Finned
- Figuring Stall Speed for What size Torque Convertor
- What Stall Speed Convertor
- 4.10 in an f-150
- Bad news @18,217 miles
- 4.10 Gears in Dallas???
- Overdrive lockout
- 2nd gear from a stop??
- Transmission service @18,000
- Tranny fluid flow direction?
- Easy to install shift kit?
- I found something really WEIRD!!!
- Tranny slipping after 34K??
- tranny question
- HelpFast! Transmission Slipping
- What do I need????
- Should I have it flushed???
- 4 x 4 Question
- Stutters going from 2nd - 3rd
- New Temp Reducing Tranny Pan
- draining the convertor
- Valve body replacement?
- better shifting 5-speed
- Tranny Slips in OverDrive
- OverDrive Button is going crazy on me?
- Question about switching to synthetic
- Need E4OD Help
- Help! My Trans Killed my Transfer Case
- Transmission Oil Filter
- B&M Tranny cooler GP!
