my E4OD and a huge headache!
why might my e4od being overheating like crazy? I have 3 problems
1) I have a shifting problem from 2 - 3, it doesn't... if I let off the gas and wait for the rpm's to drop to about 1500 it will shift on its own most of the time... sometimes I have to tap it into neutral and then back into drive.. that works most of the time too
2) a strangle wobble... sometime when shifting from 3 into OD I have a weird rattle or wobble.. almost like its shifting in and out of OD very quickly.. if I hit the gas harder and downshift for a second it will go back in to OD easy the next time around.. and if I let of the gas it goes away too... and while its doing it I notice a loss of power.. strange
3) and almost worst of all... serious overheating.. it seems that there is no top to my tranni temp.. I put in an AutoMeter Tranni Temp Gauge to monitor what was going on... I've hit about 260 and it keeps going up, but there is where I give up.. I'm too scared of what happened the day before t-day... fluid spitting out everywhere! really realluy hot... it was so hot it melted a plastic bag on the floor of my truck
I don't really know how to begin solving this problem... a guy at a local shop told me to reset the computer and let it "learn" again?? any idea's on why and how? next he said if that doesn't work I need to replace the computer module in the Tranni, and again if thats no good replace the torque converter... what should I do?
I was thinking about reseting the comp.. then if no go putting in a performace torque converter? am I off base? I need any help you can give me!
http://www.f150world.com/bigbronco93/
Well...........it's time for a new unit.
The converter is most likely coming apart and has clogged the cooler, that would explain your overheating.
This also causes a loss of pressure in the lube circuit, so the trans will slowly self destruct. Actually I have seen them blow up in just 10 to 20 miles with a clogged cooler.
I'd start looking for a replacement/rebuild really soon.
My 93 Lightning won't shift into 3rd unless you let
completely off.
90% of the time if shifts OK manually though????
It has been doing this for over a year, it is not over heating either.
The trans fluid was changed at 68k (i'm a 2nd owner)
and I had a shift kit put in at that time. It worked flawlessly
for over a year then this problem. truck has 101k on it now.
It seems like just a sensor or valve or something, but no-one
can figure it out by thinking about it.
any ideas?????
thanks guys...
Chuck in Delaware
completely off.
any ideas?????
thanks guys...
Chuck in Delaware
Chuck,
sounds like glazed plates in the direct clutch or maybe a sticky valve in the accumulator, could also be a worn boost modulator sleeve in the "A" bore of the accumulator. First thing, find a good tranny shop and have them test your solenoid, it could also be a voltage or contamination problem in the solenoid, but that's kind of rare, more common on the older ones though.
G
G
