TransGo vs Baumann vs Level 10
In the near future, I am looking to supercharge my F150 (5.4L Supercrew-ATI Procharger) I was wondering which of these kits would be adequate for my application. Will the "Bullet-Proof" Level 10 Shift Kit be necessary or should I go with TransGo or Baumann? Thanks for all the help
Baumann
I went with Baumann. I have not yet installed it. It's been too cold. I went with this kit b/c they also sold me two additional gizmo's do do a comprehensive valve body upgrade. Those two additinoal gizmo's are:
1.) a thingy that increases tranny juice flow up to the 4th gear band
2.) a thingy that improves the way the torque converter works.
One challenge at the moment is the install directions are very intimidating for me. There is some fairly strong "if you screw up you tranny will die" language.
I have a 2000 f150 4x4 5.4L 4r70w with a BAD ati procharger.
Frankinaustin,
I felt the same way about the Baumann kit on the 4x4. Take your time and it's pretty simple. Do a search on Baumann install here. There are a couple of simplifying tips on the install. One of them was on how to disconnect the electrical connectors without removing the whole connector. Good luck.
BTW, what setting do you plan to use?
GDG
GDG
