Trans Cooler
Old Dec 27, 2001 | 11:32 PM
ExplorerX50V8's Avatar
Trans Cooler
I looked under my new F-150 tonight and i notcied a small cooler by the front a/c condensor and i was like dang thats a small trans cooler and i followed the lines back to see its a PS cooler. I see the lines going into the rad and into the trans. I tow a little bit and i want this trans to last. Should i add a second cooler or would it reduce pressure too much for the trans? Also, what kind of transmission do i have, its a 2001 F-150 4.2L V6 auto.
THanks
Pat
Old Dec 28, 2001 | 01:16 PM
Neal's Avatar
Cool
HI!... You have a 4R70-W tranny. I did'nt like the factory tranny cooler or where it was located, behind the bumper so I installed a "HPP" cooler kit with electric fan.
https://www.f150online.com/galleries...4-793-7167.jpg
Old Dec 31, 2001 | 10:05 AM
Tiger's Avatar
Definitely get the cooler. A good one shouldn't cause much pressure drop and it's cheap insurance.
If you want to go a little further, get a new tranny pan with a drain plug to make changin the fluid much easire. Some even allow you to have a few extra quarts of tranny fluid. Problem here is the pan I've seen is a little pricey, ($180 or more).
Old Dec 31, 2001 | 02:32 PM
FamilyRide's Avatar
I just replaced my pan with a Ford pan with a drain plug. I paid full pop retail of $41. Order from www.oemfordparts.com for about $30.
Mine's the 4R100. The 4x4 comes with the pan with a plug. Keep in mind the filter is also different. Slightly longer tube to get down into the slightly deeper pan.
Even if you don't, if you have a speeder, dropping the pan is a breeze. I dropped my pan and accumulator valve body 3 times in 3 days tweaking the shift kit. I think there are about 273 bolts between the 2! (ok, about 20 for the pan, and 14 for the VB)
Old Jan 2, 2002 | 01:35 PM
Tiger's Avatar
FamilyRide,
Problem is you got a 4R100. Doesn't that come stock with a plug? I don't think Ford OEM's a plugged pan for a 4R70W.
Old Jan 2, 2002 | 10:46 PM
FamilyRide's Avatar
Tiger,
The 4R100 in the 4X4's have a drain but not the 2 wheel drive like mine. But I think you're right that Ford doesn't OEM one with a drain for the 4R70W but I can't say for sure.
