Trans shifts itself out of 4wd...
I have had a problem with my truck for a while. I have a 98 Expedition, it has 2wd,awd,4wd, and 4wd low. My problem is sometimes when I am in 4wd it will shift itself back and forth between 4wd and awd. I though I read that the fix may be some sensor, but I haven't looked into it. Anyone have any ideas on what the problem may be? Thanks.
i asl ohad this same problem, But i dont have awd selction. I would pull back the shifter to 4high and after a bout 10 seconds it would clikc back into 2wd...its only done it a few times, then it never did it again. probly just a fluke thing for me though
Joe
Joe
Boost,
I could be anything from a defective GEM to a lose contact to a faulty switch.
Do you have access to a Sacn tester? Shop manual? If not I could give you some simple tests to help isolate the problem.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
I too, have the intermittant problem with my 98 Expedition shifting intermittantly back and forth between AWD and 4x4. I just had it in to the dealer and of course, they could find nothing wrong. The most recent event occurred last night climbing a snowy road. I was in 4wheel hi and it shifted once to AWD and back, uncommanded. It will do this intermittantly from either switch position, with no set pattern. It appears to me to be an electronic problem, but the dealership is clueless. I too, would appreciate any and all information. Thanks.
JH
JH
problem solved.....NOT!
Three days of snow and today it did it again. The transmission shifted back and forth from 4WD to A4WD at least four times, while switch was in 4WD. I am about ready to dump this truck. GEM replaced, switch motor replaced. Maybe the switch next?
Jim Hummel
Jim Hummel
