Hydraulic line disconnect
got one better than that !!! take a flat head screw driver , usually 2 work better . push the white plastic ring in toward the trans - until you barely see it , then give a little tug and it should come out .....
Yeah, I'm having a problem with my '93. 4.9L with M5OD-r2, btw. Clutch pedal began to stick while it was running. I couldn't shift it. Turned it off, and it shifted into all gears fine. I put it in first and cranked it, and lurched it slowly back home. With it not running, the pedal works fine, and it shifts fine. Not so much when it runs. My question is, is this a simple bleed procedure, or something more serious. I'm praying it's nothing requiring removal of the tranny. I got a master cylinder just in case, but got the tool you mentioned and still can't get the line off. Hopefully the flathead screwdrivers will do it. aside from that, I haven't figured out how to disconnect the master cylinder. The thing frustrates me. Low money, no space, and need to get it running again soon.
