OverDrive Button is going crazy on me?
when the truck is in park the OD OFF light is on
when i put it in gear the light turns off?
it didnt use to do this so i got back on this here thing to ask yall's advice
just look here
www.geocities.com/thepyromaniackid
just look here
HI!... Mines been doing something like that too lately. I can only operate my overdrive button when the gear selector is in PARK, REVERSE, NUETRAL. When it's in the 3 forward gears the overdrive button does'nt work at all. I brought it into my local tranny guy and they said that they have seen this before on FORD's. They told me that the O/D wire harness coming from the gear selector gets pinched on the tilt steering mechanisim, causing a short. I'm living with it right now but it is starting to get on my nerves.
Just curious...Do either or both of you tend to use your tilt steering to get in and out of the truck alot? I'm wondering if there's a connection (or short for that matter) associated to the action of bending the wire harness a lot. I tend to just leave my tilt in one spot - no prblems so far. Either way it sounds like Ford should still get it right whether a different connector or harness should be used.
Odds are that it is a broken wire in the shift lever. I had mine break 2 times before I pulled the shift lever off and replaced the wire all the way up with one having a heaver,thicker sleeve.
What you can do is remove the O/D switch at the end of the lever (it just pops off) disconnect the wires, remove the retaining pin at the base of the lever and pull the shift lever off. This will expose the wire from the steering column on up. The break is probably at the base of the shift lever.
