Stacked Plate Vs. Finned
Hello everyone, I just got my Transgo kit but am still investigating tranny coolers. I like how the stacked plate types look like stock but do they cool as well as the finned type?
Well, which do you like better and why? I'd like your opinions, good or bad.
TIA, LE PEW
TIA, LE PEW
Tranny Cooler
I give a thumbs up to the B&M supercoolers. I recently installed mine on my 99 F150 and it fits really well and is tougher then nails, which the finned ones are not and always get banged up and look terrible, besides not telling how less effective they are with bent fins. Also, although i'm unable to give a direct quantity of cooling ability, it definatly does make a difference in temperature. I go the 24,000 GVWR rated cooler because Heat is any transmissions enemy. Also, i installed amsoil synthetic atf and a B&M shift improver kit and couldn't be happier. I just purchased a 4200# trailer and needed to set it up this way. Remember to install the cooler on the tranny return line which was the lower one on the radiator on my truck.
Also, FYI.... when you install any cooler, you probably won't be able to find a fitting to mate with Ford's tranny lines, so i flared out the end of the rubber reinforced tubing by opening needle nose pliers while inside the rubber hose and then slipped it over the flared end of the tranny line tubing. A little harder to get on, but i feel it's better then cutting the tranny line with tubing cutters. If i ever have a hose break, i can just pull the hose off, and screw in the fitting back into the radiator and i can be on my way.
just my opinion
but i'd definately go with the stacked one like B&M's
just my opinion
