35-40 mph vibration
Old Aug 18, 2000 | 07:55 PM
MOVEOVER's Avatar
Question 35-40 mph vibration
Seems to always happen under acceleration. I can feel it through the steering wheel. Anyone else noticed this? Do you think it's the tranny? Thanks
White 97 XLT SC 4.6, 4X4, 3.55ls, door cracks, tow pkg, long bed, Rhino liner, Owens running boards
Old Aug 18, 2000 | 09:19 PM
Mark Kovalsky's Avatar
Post
I think it is. It's common on the 4R70W transmission that's in your truck once the transmission fluid ages.
The solution is to do a complete transmission fluid change. Either drop the pan and drain the torque converter, or use one of the quick lube places that does a full change.
Mark
Old Aug 19, 2000 | 08:06 AM
MOVEOVER's Avatar
Post
I just had it changed about 5000 miles back.
Old Aug 22, 2000 | 12:36 AM
blackvenom97's Avatar
Post
I just purchased a 2000 F-150 with the 5.4 and the 4R70W. I have 6K on it now and I am noticing the same problem. It occurs at around 1700 RPM. I can feel it through the gas pedal just a slight vibration. I guess I will change the tranny fluid at 10K and see if this helps. As long as it dosen't get worse I suppose I can deal with it. I just don't want them to put another tranny in because Lord only knows what they will scew up then!!
Let me know if you find anything out.......
