vibration
Old Jun 11, 2000 | 08:55 PM
catdrvr's Avatar
Question vibration
I am getting a bad vibration from the rear whenever i start off from a complete stop or after backing up. If i make a turn or just take off i get a vibration for around 10 feet and then it goes away. I have noticed that the power has dropped off over the past 6 months as well. truck is 99 f150 reg. cab with 5.4 v-8. Any help would be appr.This is getting worse and really annoying.
Old Jun 16, 2000 | 04:58 PM
K JONES's Avatar
Lightbulb
MINE DID SOMETHING SIMILAR,SUDDERED PRETTY BAD OUT OF THE HOLE TURNING LEFT OR RIGHT ,THEY ADDED A BOTTLE OF FRICTION MODIFER TO THE REAREND.THIS IS A POSITIVE TRACTION ADDITIVE THAT LET'S THE CLUTCHES SLIP.IF YOURS IS UNDER 36000 MILES IT SHOULD BE FREE OF CHARGE.MINE IS A 1998 SUPERCAB 5,4 HOPE THIS HELPS
Old Jun 16, 2000 | 08:16 PM
Y2K 7700 4x4's Avatar
Unhappy
You're feeling driveline vibration (drive shaft).
To prove it to yourself, get a few of your biggest friends to sit on the tailgate and start off -- it will probably eliminate it by changing the angle more to straight by the lowering of the bed.
Y2K™
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
