fluid leaking from differential
Old Apr 29, 2000 | 09:32 PM
bgreene's Avatar
Angry fluid leaking from differential
Tranny fluid leaking from differential, I need to drop the driveshaft to get to the pinion seal which I believe is the culprit, how do I drop the drive shaft to get to the pinion seal without damaging the driveshaft because it is a two piece driveshaft system
I need help bad.
