View Full Version : 1997 - 2003 F-150
- i just bought me a 2001 sport need info
- supercharger find.. cheap!
- Best Programmer Reccomends Please
- Transmission Drain
- Im stuck... Help.
- wind noise from driver rear supercrew window
- tranny question
- 6 Inch lift and driveshaft issues
- GEM Module
- What type is my Motor???
- 1999 f-150 5.4 code p1151
- 1997 f-150 door locks don't work
- Guaging interest in tow mirrors for Supercrew
- underdrive pulleys
- oil leak
- won't crank
- Alarm issues
- A few issues with my 98
- FX4 Center cap part number?
- Rust On Roof
- Heater Core Issues
- CEL Issue
- Lightning Crate... New!
- Oil Tube Replacement Nightmare
- Brake Rotors
- startting issues
- Need Help Lifting 2WD 2002 F-150 SuperCrew
- Battery going bad?
- Can Seafoam hydro-lock a motor? NO.
- Rear axle question
- Trouble Starting 2004 Heritage STX 4.2 V6
- 2002 F150 Sport 5.4L Auto Freeze Plug
- Oil filter Guard?
- Coil pack/ coil on plug
- stone guard on brake lines?
- New Decals
- 01 F150 Screw 4x4 5.4L grinding and squealing from rear end
- HELP With Issue Please...
- Electrical issue with headlight switch and instrument lights
- Preventative Maintenance
- p0171 and p0174 but its running great
- Some Pics from last weekend Off-Road park
- F-150 Bucking and Running Rough!
- All new stuff, same old front end shake, real head scratcher!
- 18 inch rims on a 7700?!?
- Back up camera?
- Exhaust Pictures request!
- 04 & up emblems
- truck bed panel got broken
- How many miles on your original 4.6?
- Back in a F150
- Passenger side light doesn't work
- Time Sert selection
- 07 5.4L in an 02 5.4L F-150..?
- Bolt Size
- Could be a major problem?
- rattlig noise
- 2001 f150
- aggravated
- Won't pull out
- Mis-aligned door
- Fuel Pressure/Fuel Pump
- no speedometer
- Looking for a thread/member
- 97 4x4 What to look for
- Shock replacements
- Squeaky front passenger side and engine ping @ 21-2350rpm
- Coil Pack Problem
- 2002 5.4 Sudden Fuel Mileage Drop
- Multiple electrical malfunctions on same circuit (295)!
- Part Name
- Welding a rear diff.
- 1997 4.2L PCM fuse
- advice on part out
- Turn Signals stop flashing when brake is depressed 1997 f150 4x4
- Manual TC No 4x4 high light and no 4x4 1997 f150 4.6L
- 97 f150 4x4 4.6L DOHC
- Lariat wheel covers!!
- First 7700 KR!?
- Miss Firing/Putting/studering after warming up
- PlastiDip, what do you think?
- Transfer Case
- Intermittent 12v power with key on!
- torsion bars cranked and front end very low!!
- Verifying MOOG balljoint & idler arm part numbers - and a Q?
- axle swap question
- Thoughts on these tires?
- 1999 rear dif
- installed temp gauge with pics
- anyone have pics of brake line below m/c?
- What chevy motor should i put in my truck.
- 97 f150 ext. cab - Loss of turn signals
- Knock on Start up
- ignition cylinder wont line up after replacement????
- Show off those gauges!
- Codes P0303 & P0173 + anitfreeze in cylinder
- Rear Frame Section Replacement Info and Pictures
- supercrew starting prob
- Reverse lights not working
- 1997 F-150 4.2 cylinder 3 misfire
- Trailer lights problem
- knocking sound from 4r70w or transfer case
- Help! No crank no start PATs?
- 00 4x4 fogs
- Strange computer glitch?
- Brake controller
- Led Headlights
- Truck Bucking and Running rough! HELP!
- Adding Ford Subwoofer/amp
- Overdrive button does not work in drive only.
- Freeze Frame Code
- 00' F150 shaking when braking seems like not the rotors?
- 2003 losing coolant
- 2001 F150 Reliability
- Limited air flow from AC
- rabs valve - can fitting be replaced?
- ABS Light and seatbelt warning bell acting up.
- Anyone here ever lost a fuse box lid?
- Lilsle tool for 99?
- I tried all the A/C tips that I can find. I must be missing one..
- 97 with 3in lift. 33x12.50 or 35x12.50
- 1997 F-150 speedometer don't work?
- Need Help on Short Box Bed Re-Installation
- 2001 F150 XLT 4x4 A/C
- 2001 F150 XLT 4x4 Offroad
- VIN decoder
- HossPro's Build Thread "Old Red"
- Supercab windows
- Coolant leak and a few other things...
- Truck Shudders
- Insta-Lube for lifter noise
- Who has a done a 4v 5.4 swap?
- brake lines and fitting under master cyl
- FTP Sensor troubles
- wondering should I trade my truck for a new mustang????
- Code P1151 on 99 4.2 F150
- Funky trailer wiring issue - I've tried everything PLEASE HELP!!!
- 2003 5.4 spark plug change testimonial...
- 97 f150 4.2 Problems with IMRC when truck is warm
- 2002 KR - No power to seat warmers
- Steering wheel issues - how hard to repair/replace column?
- EGR leak - patch or nipple replacement - opinions
- 4.6 broken exhaust manifold options
- Replacing door light, 2002
- Tiny Metal Shavings
- Having problems with my truck
- Somebody please HELP!!!!
- Seat pricing help
- Unusual cruise control issue 2002 F150 Supercrew
- 9.75 axles
- 97 4.2 issues have us baffled...
- 09+ badges
- Need HELP from Fourm on Decision
- Replaced alternator tonight
- Having problems with 97 MSOF
- Rear Frame Replacement Suggestions
- Dumb question
- Break controller help
- 2000 F150 Windsor 4.6 Timing??
- transfer case swap
- 2001 f150 ac quit!
- 97 F150 missing but only audible on one side
- oops I bought a Chevy
- Pcm ??
- Rushing water an option on 99 F150
- 2003 speedometer calibration help
- Off Road KC lights mounted to bumper
- How to move threads and post pics from my albums
- 5.4 Rebuild!!
- Front bucket seat to bench seat?
- ABS Pump Running 03 4.6 4x4
- Engine swap
- What trailer should I buy?
- Steering and Suspension opinions wanted
- 2000 f150 5.4 drivetrain swap
- New to the Full Size World...
- 02 FX4 - Lightning headlights w/ or w/o corners?
- Available Here: 4.6/5.4 Cylinder Head Replacement Instructions
- Special Tool Substitution and Workaround for Head Replacement
- Another poor Schmuck with Drivers window problem
- 1997 F 150 4.6l 2x4 Break Problem
- Late throttle slow down
- 03, 150xl, 2wd, 4.6l, supercab center jump seat vs. bench
- Steering Stabilizer Yay or Nay?
- Need info from a dash cluster
- Fuel Pump Or Crank Sensor...
- 03 f150 4.6 no power
- RCD install?
- DeeZee Tailgate assist mod (super crew and flare side)
- 97 F-150, rear door won't open
- Successful DIY weekend
- Problems starting
- what will i need to swap a manual into my 4.2l
- egr delete
- Evap Emission Canister Bracket Rusted Out
- Help Please!
- I put coil springs on.
- Spudding at Start-up
- Instrument Cluster
- Front hub nut
- Tires. Help
- Fuel Pump issue 2002 F150 Sport 2wd
- 1997 Ford F150 4.6 and the temp. gauge is pegging out all the time
- Gear Spinning Like Noise. Need Help Identifying!!
- Help With aftermarket Remote start system
- Body lift on the way!! suggestions/tricks?
- 02 KR build up, trans and procharger.
- Pitman Arm replacement
- In need of a visor!
- Intermittent Fuel Gauge
- Rear wheel spacers after spindle lift
- Just spent $1500 on upgrades, now this!
- 02 F-150 jerking at light load
- expy console
- New Rig
- Problem while replacing radiator
- 2002 HD Valance... not mine, just passing along
- Cranking torsion keys
- 97 headliner removal
- Stupid Question 2003 Ford F-150
- 1998 F150 Lost gauges and power
- Im back!
- Swapping Rear Axle
- 03 f 150 dead battery
- Misfire and electrical gremlins?
- instrument cluster problem
- Best way to get power in a 4.6L?
- Faint Spinning Noise Under Truck. Low Power!!
- Whining Noise in 1st, 2nd, and 3rd
- Overheating 01 Screw 5.4L
- Radiator Core Support Replacement Question
- 1998 F150 4.6 4x4 Fuel Issue
- 2001 air conditioning unit
- over drive
- 97-03s with a topper
- Planning the GTFO150 (Blog style posting)
- drain gas tank in 98 f150
- Oil Consumption on Lower Mileage engine
- Trouble Setting Timing Chain - 4.6l V8 1998
- How do I install a rear end locker?
- Put money into or buy newer gas/older diesel
- Light switch illumination
- Can't find vacuum to hubs on 4x4 & hubs will not dis engage
- Auto lock feature
- Fan Clutch bolt size
- radiator question
- Will the bumper and valance from a 99 and up fits on a 98
- wont start
- Brakes blowing fuse
- Modifications
