View Full Version : 1997 - 2003 F-150
- Squeaking noise from the rear end area
- Weird noise from steering colum...
- 2wd body lift?????
- What gears to go with???
- Back up Camera
- add a leaf/ L tails Pictures
- What bull/brush guard is this
- My Progress:
- seen these? 'Qwik Valve' (replaces drain plug)
- would these seats fit in my truck
- Can i see your 3" body lift?
- Aftermarket Leather for an 03
- Front brake rotors
- Not a big deal, but it has me wondering...
- Truck got beat up today
- Bought a 97 f150 4x4 scab got a ??
- Tranny and Rear end question
- master cylinder
- cb radio mount
- Rim question
- 97-03 F-150 STX 4x4 grill guard
- My 2002 all cleaned up-Pics
- Custom Harley valance Carbon fiber with pics
- Adhesive for weather stripping
- Here's my 03 FX4 Check it out!
- Hello world! meet my truck...
- Starter or what
- PTM front end
- please, tell me about springs
- How much antifreeze do I use?
- Trans fluid temp range?
- New member, new truck!
- Lifting... what's involved? More trouble than it's worth?
- Is the TBS really worthless??
- intake manifold spacer
- 1998 5.4
- dash parts ?? swapping years ?? help ??
- My Dad's first Ford ever
- Wheel bearing service...
- Did some paint work this weekend! Before and After Pics!
- 1997 Ford 150 HELP -- head gasket/radiator/start up problem
- brake problems
- Want to add Auto-On Headlamps to 2002 F150 XLT
- Mileage for 4.6L?
- What do I need to look at when buying 97 F150?
- EGR cleaning
- Squeaky Glovebox hinges
- what do ya'll use for paint??
- I bought a truck that wont start
- unlock doors by reed switch? stumped
- New guy with a cruise control problem
- Trailer package
- Need your opinions
- help my brother
- Strande Noise
- Heated Mirrors?
- 200,000 mile club...
- MY steering wheel swap ;)
- considering selling? Talk me out of it
- engine rattle under load? 2500 rpm
- Replacing Spark Plugs ???
- What would cause a PO174 Code?????
- Before and After
- PTM Bumper on a 97 4x4 ???
- Can anyone do a photoshop for me?
- Where to get o2's
- Leaking Moonroof on a '02 Screw
- help
- ABS light, and Tail lights stay on...
- Clean Headlights
- 9.75 rear end swap w/ 4.56s complete!
- 2002 f150 7700
- Back in a fiddy FINALLY!!
- Throttle cable zip tie mod???
- Who needs patriot decals....
- MPG tune for out trucks?
- oil pressure sending unit
- 99 4.6 missing?
- what front wheel bearing is shot
- Rear Transfer Case Output Shaft Seal Removal
- brake problems
- Cleaned the engine bay this morning
- 97 F150 4x4 problems
- Should I or should I not paint my valance?
- Does he need two spares?
- lift question
- Stuck in 4H ???
- Looking to do something different with bumper...opinoins/suggestions wanted
- I need some input on what kind of rims to put on my truck....
- Power steering cooler line leak
- The surprises Buying a Used Vehicle can bring
- 03 5.4 V8 hard start + black smoke?
- Noise when going in reverse
- Advice!
- 99+ bumper swap
- Now Is the Time
- anyone have these flareside led tails?
- How to Change Coolant Temp Sensor '02 F150 5.4L
- 87 Plow Will fit on 97 150??
- Try this... see if your horn sounds off, too.
- So I figured out how to use once removed body side moldings
- new dude with a few questions...
- Shocks/Tires?
- Raising Reese hitch after body lift
- Need Help with Power Mirror Replacements for 02 Screw
- Antenna Base
- Door Panel Screws
- 5.4 V8 trans on 4.2 Engine?
- Expedition front clip swap
- Dorman upper balljoint/control arms
- 98 f150 i need help
- spark plugs
- Looking to get a DDMTuning HID Kit but confused on what to purchase?
- fabtech to bilstein shocks?
- 2001 engine swap - 4.6 liter to go into a 1997 - 2003 body
- MMMM... New Bumper
- installing a moon visor
- Alignment gona cost more then i thought.
- What's your interior colour?
- Interior Door panel advice needed
- Rear Window Replacement
- 2000 F150 Heritage
- Shift Kit vs Chip Tuner?
- 2wd lockers
- Need some expert opinions!!!
- Battery shortage?
- Mileage and Rear Axle Ratio
- Mounting ScanGauge in '02 F-150
- digital camera/camcorder?
- intake leak?
- Even the mechanic is stumped?? Can you help?
- 97 f150 - expy seats problem
- remove tailgate
- shake rattle and roll
- *PICS*What is this white crusty stuff on the bottom of motor?!
- Got brakes?
- plug and play upgrades?
- rough idle at first start...30 seconds maybe
- wheels for f150
- Vacuum diagram needed - 4.6L
- de Pinstriping - Pics Needed
- Bizarre electrical problem
- CV Boot
- My front seats squeek....
- 2000 f150 w/5.4 sputters . . . .
- 97 F150 mystery
- what size rim and tire should i put on my truck?
- Overdrive light flashing
- Disable parameter lighting
- What is involved in rear window swap
- OEM Heated seats
- tires and rims
- Blown 4.2L - Swap Question
- Rusty Door Bottom Fix w / pics
- 2 new pics of my truck
- Problems changing EGR Valve
- Tell me if this is a good deal on a 03 screw
- Level Kit
- rear end locking up when sitting for periods of time?
- Getting a new exhaust.
- Just busted a leaf spring bracket, doh!
- 2002 f150 rear axle on a 1997 f150, will it fit/work?
- Rearview camera in tailgate lock location
- dent on inside panel of tailgate
- Black vs Chrome, OBS vs NBS
- Window Tint Questions??
- Weird noise at 40-50 mph
- Whole Different Truck
- pics of my truck
- Wheels for 03 scab...bolt pattern??
- trans or shifter vibration
- Truck Transformation
- Bumpers
- I need help with wiring my Hellas
- P0353 code?
- Might be buying a 2003 F150
- Windshield wiper switch problem
- Why would RPMs fluctuate at constant crusing speed??
- Starting Problem
- Updated Interior - 1998 XLT SCAB
- Vibration at Idle
- smoked headlights on white truck
- Thought someone may be interested...
- 04 f150
- Oil Filter Relocator: where to find reasonable replacement
- Rear differential
- i need opinions....
- Is this truck lifted?
- Damn CEL! Flash then steady
- Question about air bag helper springs...
- P0171 Help
- mirrors
- difference between 2wd and 4x4 cab
- 2wd 1.5" Leveling Kit 3" Body Lift Project:
- Where do I start with the Rebirth of my truck?
- Muffler Choices
- 1997 4.2 miss
- Nissan Titan Mirrors on a 97 F 150
- How do I remove the stock mudflaps on 2003 F150?
- Start of my 2001 F150 Lariat 4x4 rebuild
- 2001 f150 2wd lift.
- Changing out my headlights- A saga of Mystic consequences
- Need a tan radio trim bezel!!!
- Truck Porn
- bustin ball joints
- Opinion on C-list find
- Anyone running 37" tires w/ 7.5" lift?
- Grille Cover?
- What do i need for 3" Body lift??
- 01 Super Crew xlt 9x20 stock Harley wheels NEEDS BIG TIRES
- White FX-4 supercab Lets see them.
- Hi-pitched front end noise...03 fx4 screw.
- 4 Wheel Drive Grind
- 4 wd problem
- Taillight only works when you hit it with your fist.
- 97 F150 Gages all out
- Dallas Area Expy Parts
- How to Clean MAF in 97-03 F-150's
- How many hash marks are in a quart of oil?
- Door Panel
- Brake upgrade
- Help!!!
- Spare Tire winch
- Leaving for Army soon, What precautions do i take with my truck?!
- My truck.. pics n vid
- finally got em in
- smoked headlights?
- What's the difference between these heads?
- Installing my Body Lift
- what tranny came in a 98 f150
- Clean....Few pics!!
- Truck Missing ???
- wipers only work in neutral?
- Weird Noise But Only At Certain Speed
- Sludge
- Idles up when clutch is pushed...
- 315 tires and NO re-gear?
- Efan brackets
- 97 F150 4x4 4.6 motor swap from Lightning/Harley
- vacum lines to 4x4 shift motor
- New guy from PA
- Suggestion help...which tails for these heads
- 03 4.6 romeo popping and burping
- New updated pics !!
- Hello all
- stupid question
- HID ??'s..
- What's the difference b/t XL and STX?
- 97 4.2 Miss
- Expedition Overhead Console
