View Full Version : 1997 - 2003 F-150
- Deep Dark samirar Secret
- Engine won't start when warm after installing BBK Underdrive Pulleys
- Father Son Project HELP 98 4.6 spark wells full of water
- 99 f150 manual transmission fly wheel bolt pattern HELP! 4.2l
- 97 F150 4x4 4R70W Problems 2H & 4H
- F-150 driver side door lock actuater
- 97 manual shift 4wd
- Front Axle Shift Fork Bypass??
- F150 Air Bag Light on LFC 27 DTC B1884 Easy fix
- 97 F-150 4.6L Engine W ... spitting fuel vapors from throttle body.
- 2002 F150 Transmission solenoids
- coin spring mod?
- Torquing spark plugs without a torque wrench?
- New Grill and Clear Lights
- Original spark plugs
- what does this look like to you guys? Intake gasket?
- Cv axle boots keep tearing
- Truck Started great yesterday. Today issues.
- changing a 4.2 to a 5.4sc 2001 f150
- 98 F-150 4.6 Brake Mod
- Help with EGR malfunction
- Can I stuff a new 6.2 into my 99 F150?
- Sway Bar
- 5.4 Ping and Stumble for 2 years
- Name that sound
- Throttle body keeps getting dirty?
- need your opinion on lift style
- 1999 5.4L Not starting - assume fuel pump
- 02 Super Cab rear door stuck closed!!
- Electrical Issues
- Better Late Than Never
- 2002 F150 issues
- 1999 F-150 with 480,000 miles!
- Trans Range Sensor Install No Special Tools Required
- Question on overhead consol
- Alarm Installation
- power steering pressure hose
- AMSoil ATF for power steering
- new 01 f150 KR HELP!!!
- 97 5.4L cooling system problem...
- Turns over but sometimes doesn't crank and stalls
- F150 V6 4.2L Hard to Diagnose Engine Misfires
- need help on lift options!!
- online parts??
- 99 f-150 5.4 - coolant issue
- Key programming.
- New to forum, 1999 F150.
- Blown Spark Plug in F150 (2000) Triton V-8
- Wheelskins
- Best lift kit options for 03 2WD 5.4L XLT?
- help with heater core
- Any specific problem...
- Truck cap brake light problem
- Bed swap to flairside
- Wheel adapters
- Bent frame?
- Door Replacement
- Replacing key fob
- 4 wheel drive problems
- 4.6 swap from explorer
- Intake
- 97-98 body onto 2000
- Bought my grandfather's XLT 5.4L - Need wheel ideas
- Longevity question
- Headlight + Tails?
- Custom Tune or Gear Change
- 5.4 vs 4.6 differences
- Show your Homemade/modded grilles
- Has anyone experienced a strage feeling coming from the engine when letting of the g
- Water pump chirp
- i need help please!!!!!!!!!!!!
- Different injectors on a 03
- Where Can I Get This Trim Piece?
- Pimp my 2001 Ford F-150
- heat
- Lowering questions
- ring and pinion swap? need help
- 2001 F150 Rear End Exchange HELP Needed
- WANTED used 97-03 F150 LIFT KIT 4WD
- Sold the Expy, bought a (GASP) Prius
- Need help removing cab on 97 f150
- 2002 F150 heater fan issues
- Thoughts on 97-03 F150 extended cab
- 2002 spare tire lock fix - 10 min.
- 2003 Crank No Start
- Engine trying to shake itself out of truck for 60 sec after start-- no CEL
- door hinges
- Dads truck wont start
- DRL stopped working
- Question about the charging system and battery draining
- Bad fuel pump
- Need help don't know what to do now
- Heater/AC blower issues
- Body Lift
- PATS issue? Truck won't start after changing plugs and COPS
- 98 F150 help!! with autopage keyless entry lock/unlock
- error codes please help
- Wheel Hub Seal
- 2000 f150
- CAI Drone?
- New Engine Mounts!
- Rough Idle, AIC?
- Did a 9.75" 3.73 posi rear ever come factory?
- Odd brake situation
- Proud new owner of a 97 Supercab
- Coil issues
- The infamous missing relay cover.
- Headlights
- Grinding noise from front end after accelerating.
- Thanks
- Fuel flooding cylinders
- somebody lift the curse!!
- Transmission slipping?
- F 150 truck wipers, interior lights, door chime, and cargo lights stopped working all
- Radio not working after jump start
- F150 1999 Start Questions
- transmission has no first gear at all, but all others work.
- 4X4 Off Road Suspension - Need a Better Ride
- Squeaky Suspension
- Need Help quickly.....2003 F150 cracked front differential
- I think i need new leaf springs.
- 2003 F150 blower issues
- Service Engine Soon Light
- too much oil in my 1999F150
- Expy Overhead Console Installed in a '99 Reg, Cab
- Need help with value of F-250 pwrstroke
- Finally a new truck
- Lean Codes. Vac Leak and Bad IAC??? Something else?
- Skid Plate Pics
- Coil Springs Removal
- Help!! truck shaking
- Which torque converter?
- Well Insurance paid.
- 2003 F150 super crew 4x4 insues
- Need some wheel help ASAP
- HELP! Cylinder 4 misfire
- Instrument cluster is acting weird!
- Replacing transfer case motor, but question about the extra wire
- Back Glass Moulding - Foam Strip Necessary?
- Simple Question?
- auto locks
- 99 f150 light switch wires gettin hot!
- Load Testing Alternator On Vehicle
- so much for preventative maintenance! :)
- Oil Filler Neck Leak.
- 1997 F150 Rattling Noise when in Drive
- Oil light on and gauge doesn't drop
- F150 Grille
- Big problem after adding new spindles.Help
- I too, must say goodby. Maybe? Thanks for everything
- Tire size for 3/4 drop
- any idea what its worth?
- 2000 - No heat until it gets very hot
- 99 possible heater core questions
- Intermittent 4x4 problem...and a fun story.
- Adding auxilary power to the fold down center seat console
- Intermittent no start and o/d light
- -44 offset who's running bigger
- Fuel Mileage
- Codes P1131 and P1151 and more..
- advise
- whats a fair price to ask
- Flushing the radiator
- 2001 Ford F150, 4.6L, Manual Transmissi0n
- Maybe last post here
- Need help selecting nerf bars
- pink and blue vacuum lines, have an open black one, is this a vent?
- overdrive switch and shorts
- '97 F150 Weird Chime - 5 beeps x 5 ?
- New 20" LED Bar!
- Tranny acting up on me
- 01 5.4 Screw with weird starting issue
- Doing some maintenance, want some advise
- cylinder head cc?
- RAP module installation
- 1998 expedition 4.6 sputters.
- Any 97-03 4x4's for sale?
- Navigator/Expedition AWD system in F-150
- question about the gotts mod/ silencer
- Desperately In Need of Help
- Gas gauge moving up and down
- 2003 F150 4 wheel drive will not engage while moving
- 98 F150 5.4L Leak behind engine
- Truck rocks back and forth when coming to a stop
- Transmission won't go into 2nd
- Strange issue
- another power window thread...oh yay!
- Heavy Coolant Leak
- stalling out
- P0171 and P0174
- Hole in exhaust manifold
- No Heat
- Windshield wipers not functioning
- 4WD won't engage and no light. Where to start?
- so when it rains it pours.
- heater blower
- 98 F150 6 cyl automatic trans will not turn over
- S.O.S. Transmission not going into drive.
- 7 bolt rims
- 2000 rocker panels
- starter run on
- Best price on 2000 5.4 intake manifold
- 2wd lift questions
- 1997 Passenger Door Won't Open
- Front end conversion
- need OEM parts, but don't know where to find
- 2000 ford f150 electrical issues
- Mpg drop after cat replacement
- 2002 F150 XLT- Overhead console not working
- cranks but won't start
- anyone ever lost all keys to their truck?
- Blown out plug
- Need bumper advice
- 4 hi humming noise normal?
- ran clutch fluid out how do i get air out
- Very Low Fuel Pressure!!!
- intake manifold
- Help Mod ideas
- 2002 Ford F150
- steering lock not working
- 4x4 not engaging
- Coolant or oil leak?
- Suspension lifts
- Cruise Control Inoperative Diagnose
- coolant loss
- E-fans: Anybody know how to find tech data on Ford OEM fans?
- Engine Starting Issue
- '99 5.4 p1151
- Help!! Truck dies!
- Skipping Problem
- 9 NO start HELP!!!!
- Dual, same side, rear exit exhaust? Anyone?
- crossover tube manifold fitting.....
- Clunk hitting bumps!!
- huge mistakes.....crankshaft pulley throttle position gear
- Wanted: FX4 Wheels
- New exaust today....
- DIY Long travel IFS???? SAS?
- 4x4 Problems- Hubs are acting up
- '01 Cold Start Issue
- Foreign object found in cylinder 6?
- my '99 baby status HELP please
- 2002 Ford F150 Climate control blower stopped working
- Lund Lunar Visor?
- idle problems need help trying to sell
- How Much Should I Sell My Truck For?
- where in the world do you find these rims!?
- Will a 04 f150 6 1/2 truck cap fit 03 f150 6 1/2 ft bed?
- Beep sound from fuse box
- Help! Engine stalls
