stalling out
Old Dec 9, 2013 | 08:27 PM
Rodeo302's Avatar
stalling out
Hi I for a 97 f150 with the 5.4 and the e4od tranny and for some reason it stalls out when I put it in drive or reverse in the winter this happened last year but in reverse only and it's only happening when the truck is cold any thoughts ideas or anything would be helpful
Posted from F150online.com App for Android
Old Dec 9, 2013 | 11:09 PM
4x4wolf's Avatar
IAC valves act up in the cold weather, pretty cheap and easy fix if that's it.
Old Dec 10, 2013 | 01:01 PM
Rodeo302's Avatar
How do I check then and what are they
Old Dec 10, 2013 | 05:02 PM
The IAC (idle air control) valve is on top of the throttle body.
Pull it, you can try cleaning it with WD-40, but they are reasonably inexpensive to replace.
Old Dec 10, 2013 | 06:11 PM
Rodeo302's Avatar
Thanks I'll take a look this weekend since I work sun up to sun down right now and post my results
Old Dec 10, 2013 | 10:33 PM
4x4wolf's Avatar
Good luck, mine gave up late last winter and had to fix in the cold but was a fast fix
Old Dec 11, 2013 | 10:36 AM
Rodeo302's Avatar
Ya I got a heated garage to work in but I park outside
Old Dec 12, 2013 | 10:39 PM
Shadow_Death's Avatar
Another thing to consider is the Rubber 90 degree elbow at the end of your PCV hose that runs into the back of the intake manifold.
If this is the cause it's about $5 to fix.
Old Dec 13, 2013 | 12:51 AM
If the PCV elbow is leaking it should be throwing lean codes.
Old Dec 14, 2013 | 01:15 AM
Mine didn't.
