View Full Version : 1997 - 2003 F-150
- Supercharger
- Need help ASAP
- Fuel Gauge not working
- Cruise Control Recall Question
- Speedo sticking?
- Sticky Automatic gear selector
- help with plugs!
- 4wd not working, need help!
- New Truck! Need Opinions
- Man do I feel imbarassed.... I need a 4X4.. funny
- sooo.... my wheel fell off today... curious? pics inside
- I know everyone is going to say this is a bad Idea....BUT
- Photoshop request
- Door seam corrosion protection
- tail light mod idea
- what problems have you ran into with these trucks??
- Iam new and got a question 4x4
- Buying a 1999 F-150
- Replacing Rear differential fluid/gasket... any vents?
- F150 Codes
- Looking for aftermarket console etc.
- Preventative Maint.
- Tryin to decide on programmer?? Edge Or SuperChips
- Thinking about doing vinyl stripes
- Installed Lights behind Grill
- Wider Tires?
- Painted my grille and leveling kit pics
- PCV Hose assembly replacement repair cost? Am I being ripped off? HELP!
- STX Valence and Fogs
- computer reset
- tool box question
- Odometer went BLANK!!!!!!!
- front end vibration while turning from a stop
- Xenon lights
- rear door panel removal 1997 f 150
- Drivers side tail light
- how do i find what my axle ratio? help
- Yea or Nay
- 1998 putting in a new motor 4.2
- Error Code P0442
- Frontier full replacement bumper pics
- Does anyone have some feedback for this site...
- prerunner f150
- 98 F150 2wd Longbed 5.4
- Detailed my truck today
- Best Tire for 2wd?
- any body use O'Reilly brake pads?
- Need help mounting a Thule roof rack on my Super Crew
- FarmboyFabrications-Ford F150 with a Cummins 12 Valve
- Rear window leak
- Lift or Lower?
- Dash Lights out, need help
- Heated seat not working
- '97 problems: OBD-II won't link, Fuel injectors won't fire- PCM Problems?
- Need some help
- What is this thingy?
- toolbox and air filter/throttle body spacer
- What is the normal life expectancy of my truck?
- Cabin Air Filter
- new exhaust tips.
- Just passed 125k
- 1997 60/40 console compatibility question
- Next mod advice/opinions
- Functional advantage and 2d order impacts
- Custom bumper/winch mount build
- Sorry for aother tire question...
- Recon Line of Fire and Smoked Lightning Heads installed
- I need help!!!
- any green extended 4x4's out there with aftermarket wheels/tires
- Lightning bumper cover
- rear end gears for 35" tires what to use
- Heater Core Question
- O2 sensor change
- Spark Plugs and COPs
- Ford F150 ac blows out defrost all the time
- cant decide between my truck and a subaru
- Photoshop Request
- 99+ Cluster Swap
- 1998 f150 4x4 blowing cold air
- Front Differential Won't Engage
- new here got some questions
- look at what i gots today
- Lincoln Navigator Front End Conversion (Pics!!)
- Interior light delay
- Noob already asking for help.
- Shroud necessary?
- 1999 F150 4.2L engine drive belt and idler pulley questions
- Body Lift is on!!!
- Check out this truck!
- Mirror replacement
- Ext cab vent window hardware
- Clicking/Tapping Noise - Oil Treatment
- Transponder keys
- special touches
- finally got everything installed...
- 2003 5.4L 2v and SeAfOaM, BK 44, etc
- replacing cv boot
- weird noise when start NEED HELP
- My thoughts on Monroe Reflex shocks
- help!
- Rear Window Trim
- dreaded ticking sound
- HELP: Wiring up Fog Lights
- Tell me it isn't so!!!!!
- Seat Upgrade
- Miss fire
- Replace fuel tank?
- Newby would like some advice
- engine dies, short?
- Take A Look ??
- just wanted to share my screw
- headlights,
- Looking at an '01 screw
- a few of my problems, any help would be great.
- Body Lift Going On Tomorrow!!!
- Need opinions
- 8.8 to 9.75 Swap...
- 7700 Package
- grille gaurd fitment?
- shakin screw
- Help! Need Complete Part Number
- gas milage
- Continuity/Short question - Starter
- i need some help
- Got a new baby!
- Speedometer 85-100?
- ROLL CALL!! all super cab, long beds!!
- Tonneau cover ?
- Help with wheel fitment please!!
- A/C Clutch always engaged when the control switch isn't on OFF
- First maintenance for my 01 F-150
- Herculinered my doors and rocker panels - pics
- power window
- going form 35s to 38s
- rotten eggs
- cruise control
- Loose cat heat shield
- 6+3 concern
- Lifting my second Supercrew
- 98 XLT: Leaking brake line ... that does what?
- question about lifting,
- Fog Lights?
- Heater control fix for potentiometer
- New Member with a question.....
- need help with 2000 f150 4X4
- Truck got a kill!
- HELP...Blowing Fuse #15 in 01 SuperCrew
- Canister Vent Solenoid YL5A-9F945-AA
- 2001 F-150 Hesitation
- Subs
- 2001 F150 Cruise Control Inop
- i'm retarded
- key chime delete
- Let me see yo vertical grille.
- no spark cylinders 1-2-3
- Removing glovebox
- Front drivers axle seal
- Plug change now Misses
- fuel pressure regulator
- new gears? and possible cost?
- drop fuel tank or remove bed?
- going nuts
- stumped
- All Black and Blue Thread
- Finally hit 100k!
- Service Manuals
- 03 F150 SCREW key
- wanting to put 5.0 in where 4.2 once was
- Photoshop request
- SuperCrew seats in Extended Cab ??
- What size rearend do i Have? Pic.
- Anyone have tips or a how to in daystar level kit?
- Lets see the 6 + 3 club
- Truck dies at start...
- s/c rear windows
- supercrew/trailer???
- 4x Valence on a 2x
- Rear axle seal replacement...
- 4.6..is it worth it?
- Air in Coolant System
- Fan Blower speeds Lo 2 and 3 out... Hi still works
- Rear Bumper for 97 F150 Step Side Sport 4x4
- 97-04 heritage members stand and be counted
- Starter gone out? Need suggestions on a problem
- My truck TRANSFORMED!
- Transmission Fluid and Filter Change
- Picked up my 99 Supercab today
- How-To: Install Drop Shackles on your 1997-2003 F-150
- Seat help?
- 2003 f150 4x4 not working
- humming noise
- Where to buy cheap steel 17" wheels for my '03 4x4 F150 5-lug?
- 3" body lift
- Sweet Nighttime Pics! (56K warning)
- 2000 Ext Cab Rear Windshield Leaking
- Window trim
- Just out of curiosity
- Put Lights in Grill 2002 F-150
- I dont know what im doing anymore
- Raced a Marauder today
- xlt???
- towing questions
- QUESTION! Grill Guard Fitment with Year to Year Changes!! HELP!
- lifted 2wd thread
- Need a little help
- Overdrive button problem
- chip?
- F150 -vs- Suburban
- Painted Driveshaft
- Now is the time to trade up.
- any one have any subs under their back seat?????
- Quick question...will a 97-02 body lift fit on my 03??
- Idler Arm
- brake problems
- Can't move shifter, ABS light on
- Color on Wheels
- Add-a-leaf
- Looking for a leveling kit
- 4.88 or 5.13 regearing
- 2000 f150 scab ,5.4l 4x4
- Have a 4.6L stutter sometimes ,check my fuel results
- I'm officially in the family...pics!
- Auto Enginuity for PC use
- how to tint windows, kind of
- 60-40 seat cover for 97 F-150
- Code PO 118 Help
- having some majory tranny issues...
- Adding factory Power Windows/Locks
- Quick question
- new projectors
- liftin truck question
- trans problem?
- putting in new deck
- Low Speed (<15mph) Shudder Under Braking, Felt in Steering
- Rough Country lift 4 in
- Rough idle / acceleration, runs fine when warm
- Ford lightning head lamp
- Headlamp warning chimes not working
- $1,200 Toilet Seat
- ifs locker??
- A question about airbags.
- Finding door ajar switch 1997
- My Free Gas Cap holder mod- My version start to finish in two seconds!
- Deep Dark Patman Secret
- How's this Price?
- rear lic plate lights fuse
- P1135
- Bed Extender help...
- Question on Body Lift
- Underdrive pulley's worth it ? really?
