liftin truck question
Old Sep 8, 2009 | 07:45 PM
fordordie1's Avatar
Exclamation liftin truck question
hello all. i just got a ford f150 supercab xlt 2002. i dont have alot of money and still in highschool and was wondering. does a 3" body lift with 35" look ok? i know suspention lifts are expencice and frankly dont have the money for it and just want that sporty offroad look. there is nowhere to go offroading around me so clarence isnt what im lookin for. another thing what are the advantages and most imporatly the disadvantages of body lifts.
please help
Old Sep 8, 2009 | 09:10 PM
crums440's Avatar
i am an 11th grader and put my body lift on with 35s, it looks pretty good imo, just get a kit off of performanceaccessories.com they work good, get lots of penetrating oil and be ready to spend a lot of time on loosening the bolts, i spent a day and a half on mine, but i had all the tools to get every bolt out and the sheared bolts, its very time consuming but in the end its worth it,. look at my sig for what i did,
Old Sep 8, 2009 | 09:27 PM
str8t six's Avatar
Summitracimg.com has good pricing on performance accesories lifts. I have pics of when I had my body lift and 35's in my gallery. It's not hard to put on it only took me and two other people a day to put it on. It's a cheap and easy way to get a lift and looks great.
Old Sep 8, 2009 | 09:51 PM
wandell's Avatar
I agree. Also, 33's or 35's look great on a 4x4 with a body lift.
Old Sep 14, 2009 | 06:25 PM
fordordie1's Avatar
a buddy of mine said dont do it because if messes with your steering,mpg, and drivetrain. is that true? and is it really worth it? i want to do it but messing with my steering kinda makes me not want to
Old Sep 14, 2009 | 06:29 PM
crums440's Avatar
the kits from performance accessories have a steering extension, so the steering isnt a problem, the mpg would go down if you put bigger tires on, and it doesnt mess with your drive train one bit, at least from what ive noticed, unless you crank your t-bars, then you need an alignment
Old Sep 14, 2009 | 09:51 PM
wandell's Avatar
Right.
Old Dec 15, 2010 | 05:28 PM
fordordie1's Avatar
i got my tbars cranked now. aint got an alighnment yet. thought it was pointless if ima get new tires(bigger) on the first
Old Dec 15, 2010 | 06:11 PM
MuddYMesS's Avatar
get an alignment and add the body lift and you will be set. a body lift sets the body of the truck higher off the frame itself, in no way does a body lift mess with the drivetrain. as for the steering the performnce accesorys kit includes a spacer that extends your steering linkage. good luck my friend
Old Dec 15, 2010 | 10:13 PM
eheller's Avatar
let me know how the lift goes. i am in the same boat with money and a body lift for my 02 KR and im in highschool too. best of luck
Old Dec 16, 2010 | 02:14 AM
ford4life.'s Avatar
There is alot of Highs schoolers here.. anyway body lifts are fine.. the only reason for me wanting a susp over body is i dont like having the gap between the frame and body just me though.. if it was not for that i would do body..
Old Dec 16, 2010 | 02:41 AM
Lightning Expo's Avatar
With gap guards and bumper relocation kits now you can barely even tell. Hell, you can even get your tow hooks back in the factory location with some modification. Put some steps on there and you will never know.
Old Dec 16, 2010 | 09:58 AM
fordordie1's Avatar
i got my tars cranked now and ima try a 315/75/16 and see what happends
Old Dec 16, 2010 | 11:31 AM
97isnotold's Avatar
yep i'm a senior in highschool, you can get 3.5" lift spindles for about $400. I just put lift spindles on my truck, only took about 4 hours for two spindles and blocks and U bolts in the back
Old Dec 16, 2010 | 01:59 PM
03Fx4JD's Avatar
I remember those days... It was easier to mod back then though b/c you didnt need a spacer or cranked bars... you just stuffed them in there like this:
Those are 33x12.50's no lift. No rub either Gotta love older trucks! Im pretty sure 36's would have stuffed in there w/ just a level kit, if they were around then. I miss that truck. Was my first truck, and well, there were a LOT of first's in that truck.. and I'll just leave it at that
