View Full Version : 1997 - 2003 F-150
- P0705
- 2002 5.4 ignition sequence sounds
- 2003 f150 no start
- 1997 4.2L Manual, Replace Diff & upgrade to discs
- 2002 F150 "FX4" (off road) Shocks - Experiences and Suggestions
- MMO: from: smoke at cold start-up to: No Smoke at cold start-up
- Spindle lift issues
- OEM Gas Tanks and Sizes....
- running sluggish, slow shift between 2nd and 3rd
- Windshield replacement?
- 5.4l 2 Valve - Engine Oil & Filter
- Looking for some 8.8 rear axle information
- 5.4l 2 Valve-Reading removed spark plugs w/ 45,000 miles on them
- 5.4l 2 Valve - do Not use Anti-Seize on spark plug threads But... Why??
- 97 F-150 stall and won't start for hours after
- 2002 Supercrew 2wd 4.6 parts list timing chain replacement
- Adding an 'Emeregency Brake is On' Buzzer
- where to find "Online Parts Diagrams" for: 2001 F150 5.4l 4x4?
- front AXLE stub bearing
- Any Custom Interiors?
- 7.5in fabtech lift
- Which "Scanner" is Best or... which Scanner do you use?
- 2002 F-150 dies with headlamps on pressing brake
- Upper and lower control arm torque specs
- 5.4l - 2 valve engine, developed a miss - asking for advice/expertise
- Codes P0308 and P0113
- clogged Fuel Rail screen 5.4 do they need this?
- Need help with lean bank 1 & 2 codes
- 1997 Bumper Swap
- Trailer/Rear Light Wiring Harness
- "turn signal on" clicking sound coming of stereo speakers
- 4.2l stuck tensioner bolt
- 98’ f150 4.2 transmission stuck in 2nd
- After market backup Camera
- Two quick battwey questions with pics!
- 2000 F150 5.4 Performance Mods?
- 04 f150 heritage annoying p0455 code
- Battery clamp hold down question
- 4x4 Wont enguage after weeks of throwing parts at it.
- Help
- Blower motor resistor
- 98 F-150 bouncing oil gauge needle 4.2L 198k miles FIX!!!
- Extreme Vacuum problems
- Help!! Where do these tubes go???!!!!
- Electrical wire color coding harness for engine bay
- Key ignition switch fails 1/4 of the time
- Help
- 98 ford f150 smog sensor reset issue
- Swapping side mirrors will they fit? Need some help
- 1998 F150 Speedo Issue
- Looking to buy a topper for my truck. Will it fit.
- Need Help!
- 99 F-150 cluster swap.NEED HELP!!
- 2002 v8 supercrew, power window driver's side not working
- 97 clutch/trans problem
- 1999 F150 PATS Tx Rx issue
- Best "Cheapish" Meter to Measure Milliamps
- Tire Size
- Locating oil pan drain plug
- 98 F150 not charging. Need HELP!
- Check engine light
- Where are all the ground locations on 2001 F150?
- 2000 ford f150 5.4l bi fuel
- 99 F150 Cranks but No Start Help Needed!
- Spark plug spinning
- Front suspension and steering STILL a problem...
- Airbag Light
- Fuel filler neck sleeve cracked, how do I remove?
- 2003 ford thunder
- please help
- F-150 4.6 2v vs Mustang 4.6 2v
- 99 4.6 drop in 02
- Transmission
- Injector Harness Multimeter Reading
- Advice needed (Pic heavy)
- 99 f150 5.4 need help.
- 1997 F150 4.6L 5 speed manual stuck in 4 wheel
- Electrical trouble, I think.
- Get UP TO $500 OFF MSRP on Borla Exhaust Systems
- F150 Running Rich
- 02 Engine Swap
- 2002 5.4 oil leak
- looking for knowledge/answers
- Windows not working
- 4.6 to 5.4 Swap
- 2000 f-150 4.6L V8 turbo charge
- Torsion bar adjustment
- 2000 f150 4.6
- 1997 f250 7 lug lower control arm? 4wd
- Catylst and evap systems not ready
- Control Arms
- Weird electrical malfunction
- Electrical short now no start
- Engine goes crazy when it's very cold
- How to tell if its a factory alarm or aftermarket?
- F150 4.2 1997
- 1997 f250 XLT 7700 GVWR 7 lug
- Speedometer and Brake issues
- 1997 4.6L to 1998 4.6L
- '98 Exhaust bracket ID
- Lean trim @ high rpm
- 03 4.2 to 4.6 swap
- Possible vacuum leak??
- Engine tag
- AC vents weak and whistling only through passenger side
- Electrical Issues
- 99 f150 4.6L triton V8 knock sensor
- Water Leak inside cab
- Cruise Control Problem
- 97-04 f150 door swap
- Cold snap, Poor idle W/cold. IAC? Code po153
- Trouble finding front shock
- Consistent intermittent temperatures spikes.
- Can I use a battery saver to prevent PATS trouble?
- Is my truck lifted??
- 1998 f150 ac not working correctly
- 2000 F150 4.2 V6 Transmission Won't Go Into Gear
- Disable Fuel Pump
- Headlights
- Decisions, decisions!
- Need some advice
- Swapping 99 intake to 2003 engine
- Truck cranks wont start
- 2002 SCAB leather interior REPLACEMENT upholstry
- 2002 Scab front seatbelts
- 5.4l 2 valve intake issues
- 5 long beeps
- Key in Ignition Chime
- 2001 F150 5.4 V8 weird buzzing noise underhood
- Upper Seat belt bolt torque spec?
- Running rough and lacks power
- Apologies and help with crank / no start
- Prove it with a picture
- will they swap???
- 1998 f150 - Speedo, odo, cruise not working
- Foggy Headlights
- Fuel/Emissions/No-start
- Running like it's missing
- Disabling lights when fobbing truck
- Front seat swap
- 2001 F150 Upper control arm bracket question
- 4WD Actuator
- 1999 F150 5.4L Battery gage suddenly headed for "L"
- 7700 springs installed.
- Correct Sway Bar Bushing
- Tow mirror wiring help needed
- how to cap off return fuel line from fuel rail
- Performance intake
- 2003 F150 4x4 inop
- Bed swap
- V6 4.2L fuel pressure specifications
- Donor trucks for 4.6L to fit 98 F-150
- 2002 fog lamps quit
- brake controller
- 2001 Scab specific lightbar brackets
- Brush guard
- Speedometer and odometer incorrect after recall
- 2001 crew cab questions.
- Another 4.6L PI swap. Need Help!!!
- Fuel pump brand recommendations
- ABS Code Questions
- Name of our bed
- Fuel pump housing
- Front Door Window Issues
- 98' F150 Alignment
- Coolant woes...
- 8.8 rear end
- cab brake light works backwards
- Coolant Leak
- Catch Can
- Replaced gauge pod, theft light keeps flashing.
- Removed remote start
- brake light on dash with park brake engaged?
- 2001 f150 height?
- wiring harness on a 2001 f150 7700 XL
- 1998-1999 5.4 engine NPI-PI change questions f150 4x4
- 2002 F150 XLT Triton - Stuck in park, no high beams, no dome light
- 4WD Not Working - Need Help Please!
- AC/heat switch and blend motor testing
- Cruise control - tried diagnostic tests, low voltage pin 5
- Intermittent wiper issue
- Change in idler pulley size between years
- 98 f150 Steering Oddity.
- Power steering pump shaft play
- Broken Coil Spring - looking for DIY
- 98 F150 blower will not work
- driver's door not unlocking
- Harley-Davidson edition pre-runner build
- 03 f150 steering wheel swap
- 98 F150 Overdrive issue while hauling
- MAF question
- Cylinder Misfire, no constant power
- Gotts mod
- Coolant Leak Help
- Blew #24 maxi fuse
- fuse
- shocks
- Drove my 02 F150 6,125 miles in the last 16 days
- 2001 Ford F-150 xlt bolt patterns
- Lock rear end while in 2wd??
- Jcase fuses for 2003 F150
- Minimum line for brake master
- Seat conversion
- Vibration behind dash after all cats replaced
- New F150 Owner - advice needed
- 02 cruise control
- 03 PI to 97 5.4 swap
- Blower motor does not work on any speed
- My Truck Likes Attention
- Altenator GOOD but not charging?
- Problem with AC/Heat fan
- 97 v8 4.6liter engine lesking coolant but csn't pinpoint where!
- ‘99 Coolant Temp Spikes after Pump/Clutch Replacement
- 2003 4.2L v6 SC parking brake cable assembly
- Cv axle replacement
- Backup camera
- what is a good aftermarket replacement for a MAF sensor
- Electrical is it GEM?
- battery drain
- Moldy smell from AC
- Rear AC
- Broken bolt on thermostat housing (but it's worse than that!)
- Intermittent display of odometer
- 99 F150 4.2l excessive vacuum
- proper way to check upper and lower balljoints
- Misfire with P0353 code
- Revive ‘01 F150
- Seats (again) - Anyone tried swapping a newer interior in?
- 98 F-150 P0301 3, 4 & 5 misfire
- What’s the highest miles seen on 1997- 2003 F150?
- 4R100 Swap
- 97 f150 4.2 automatic swap out with 4.6 automatic 4x4?
- Things to look out for 2003 XLT 5.4
- 2001 f150. What line off master cylinder is Primary and secondary.
- Can I get alignment with a different wheel on the right rear?
- Possible help figuring out what lift I have
- VIN info? What do I have?
- horn goes off on its own, how to fix
- 97 4.6 #4 cylinder spark plug problems
- 2002 F150 rear end problems
- Gas?
- 2002 4.6 reliable power adder?
- death wobble
- Do I have a 97, a 99 4.6.
- Headlights Quit working
- Ruffstuff Specilaties Diff Cover!!!!!
- 2001 Tritan, Maintenance, oil change
- Clutch Master Cylinder Pushrod Mystery
- Spoof '80s commercial is hilarious
