98' F150 Alignment
Have you replaced bent stuff?
I am also willing to bet your frame is bent. Caster really isn't that important. Will make it pull, but typically doesn't eat tires like crazy, like a toe or camber issue would.also what about suspension bushings?
Caster is usually half a degree higher on the right side to counterbalance roads being crowned in the US
CASTER is your friend ...if you like to drive over 30 mph AND have control!!.....thats what keeps it pointing straight when you let go of the wheel....granted OP has +caster....so not a BAD thing .May make steering a little sluggish at slow speeds.You did put cam bolts in BOTH upper control arm mounts right?
