PDA
View Full Version : 1997 - 2003 F-150
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. tommy
  2. 2001 F150 won't start
  3. Can I put a newer motor in my 97 4.2 5 spd
  4. Low Fuel and Low Oil Pressure Signals Flash On
  5. Shifter Sloppy and makes weird noise.
  6. 98' speedometer ?
  7. 1 year...5 idler arms lol
  8. Pitman Arm
  9. Fitting 35s with a 2.5 inch leveling kit in front and 1 inch block in the back?
  10. Getting a crate motor from Ford
  11. 2000 F150 5.4 4x4 Ac problems
  12. Need power
  13. Anyone have these wheel or know what they are???
  14. New Truck - Intake Manifold and Other Maint
  15. 2000 F150 axle woes
  16. Sold my truck. :) one thing left over, Magnaflow 15749 nib (see classifieds)
  17. cruise control and horn problem solved (it was not the clock spring)
  18. Factory Nerf bars, re-conditioned.
  19. After market tires
  20. Need new bumper for my 01 supercrew
  21. axle/gear question
  22. Passenger seat won't recline!
  23. 350,000 miles!!! 1998 XLT - Built FORD Tough!!!
  24. Humming noise 97 f150
  25. Ford tow mirrors
  26. 2001 upper control arms
  27. 98 f150 4X4 not working
  28. Wheel/Tire fit for 2002 King Ranch
  29. tilt wheel issue 2001 F150 Lariat
  30. 2000 F150 wheel spacer help!!!
  31. Experts help! It's... A new noise!
  32. How do I remove the front bumper's upper/top pad? Don't want to break the clips
  33. 1999 no air
  34. New COP, now no power
  35. Blew out a spark plug
  36. Added secondary sunvisor from Navigator
  37. 97 f-150 frame problems
  38. just had 5.4 rebuilt, running rough and P0174
  39. Front parking brake cable
  40. Slow Power Window Fixed
  41. I need Battery help
  42. broken torsion rod
  43. ECM calibration code ?s
  44. 02 f150 lip mode?? Help please
  45. 5.4 SVT MS3X log file?
  46. want more power
  47. Grey plug under dash - what is it?
  48. Ford crate engine or repair head gasket
  49. Electric Fan Signal Wire...
  50. Question about the gasket where the slip yoke goes into the T case
  51. Clear Coated Wheels??
  52. Expedition engine swap into f-150
  53. Code P1132 and Code P1152 Running rich
  54. Air charge sensor reading vs. ambient
  55. Fuel Injector rebuild kits
  56. Coolant Leak
  57. Lets see those Arizona beige 97-03's
  58. 5.4 2V Ticking
  59. 1997 F-150 XLT Instrument Cluster Issues
  60. Trailering my truck
  61. just sold her
  62. 2002 Supercrew B Pillar Trim
  63. 18x10 on 305/65r18 will they fit
  64. 11 years, 115K miles, truck's been good, gotta move on
  65. Keys locked in truck. Need help!!!
  66. Please Help No Start
  67. Driver side window
  68. Rear 7 way trailer plug 2003 fx4
  69. 1997 Fordf150 5.4L CEL P0306, P0308
  70. F150 Super Duty
  71. 97 F150 weird no start
  72. Electrical issues after heater-core replacement
  73. major electrical problems. need help
  74. 5.4 swapped in place of 4.6
  75. Need help
  76. check engine light
  77. lift kit questions
  78. Crusie control switches light up?
  79. Cutting out on hard Acceleration, No codes.
  80. CV Boot Issue
  81. I have a fun new noise that I need help diagnosing
  82. Tell me about the V6 4x4 drivetrain
  83. 2003 F150 4.6 Triton throttle body part?
  84. No brakes, turn signals, running lights 98 f150 ext cab 4x4
  85. Tuner
  86. Need help with aftermarket wheel
  87. Idler Arm/other woes
  88. Rattle rattle. Really could use some help.
  89. "Auto and Art" headlights
  90. 03 f150 .. code help . p0170,p0171
  91. 2003 F150 4.6 Triton
  92. Mc 5w30
  93. Please Help!!
  94. leveling my 01' 2wd supercrew. Cant decide on wheels and tires???
  95. Frt brake caliper sticking help needed?
  96. Weird noisy clatter from my 5.4. Any ideas?
  97. Brakemotive reviews
  98. Cab lights
  99. Headers or not?
  100. Dome Lights Stay On!
  101. Ordered wrong braided brake lines.
  102. Cb Set up???
  103. 2001 Front Impact Sensors
  104. Issue with the pats system
  105. Got my new gears
  106. What Kind of Paint Damage is This?!
  107. Help!!!
  108. Harley Davidson Chrome Grille
  109. got my Lincoln interior in!
  110. 1998 F-150 aftermarket wheel wells guard liners?
  111. 1997 5.4 going into a 2001 advice ?
  112. Cranked T Bars and question?
  113. 2001 with LSD and the shudder when turning
  114. Speedometer quit working, then started working again, but showing wrong speed...
  115. No compression - I can't see why
  116. Intermittent bringing noise not hubs not brakes
  117. Restoring this 2001 beast mostly cosmetic.
  118. Manual Trans Change, clanging in gears
  119. Interchangeability of wheels.
  120. Time lapse of pulling the intake manifold off 99 Expedition
  121. Stuck between tires. NEED HELP!
  122. Help My Truck Wont Go In Four Wheel Drive
  123. No Speedometer
  124. sold my buddy
  125. 98 F150 V8 5.4 won't start
  126. 1999 F150 power window
  127. ground up 5.4 build
  128. Over pressurized fuel tank... burping gas cap
  129. 02 5.4 idle rough after plug blow out
  130. NEED OPINIONS ON WHEELS/tires!!!!
  131. Fixed my hard 1-2 shift!!
  132. aircondition issue
  133. Unique Starting Problem
  134. 98 5.4 engine harness pic needed!
  135. is it possible to put a step side bed from a regular cab on to supercrew?
  136. Camo Seat covers for 2002 F150 SuperCrew
  137. same or new engine for perf parts?
  138. New Project - 02 Supercrew 4x4
  139. F150/7700 trouble
  140. Need HELP
  141. FPDM 2001 F150 location?????
  142. Opinions: What should I do next to my 2002 F150 SuperCrew
  143. Rotational front end squeak 2002 F150 SuperCrew 4x4
  144. To buy or not to buy... 02 F150
  145. best exhaust
  146. Rear Diff clunk and squealing
  147. Aftermarket Differential Locks For 97-03 F-150?
  148. Getting a new key cut
  149. 99 4.2 running rough and hard to start
  150. 2003 Supercrew - most trouble free vehicle I have ever had 255,000 and strong !
  151. Sloppy steering when wind blows hard - 2002 Supercrew 4x4
  152. 2001 F150 coolant leak when tank is filled.
  153. 1997 4x4 randomly started using a lot of gas.
  154. Repaired SCAB rear door upper latches
  155. upgrading to 14mm lugs from 12.. will abs rotor fit non abs spindle?
  156. 4.2L V6 Intake Manifold gasket / Coolant bypass tube Job gone bad
  157. my new ride
  158. please help!! 97 f150 5.4
  159. Looking to purchase on 03, maintenance suggestions anyone?
  160. New ticking sound
  161. Bed removal?
  162. fuel level gauge
  163. overheating help
  164. Vacuum line end missing - where'd it connect?
  165. Ford F-150 rear breaks
  166. 98 f150 4x4 problem
  167. 2001 4x4 slow to disengage
  168. terrible idol and missing while accelerating
  169. Early build date 97 F150 header panel/ headlight/turn signal advice
  170. Intake manifold replacement due to antfreeze leak
  171. BAD Coolant leak
  172. heat
  173. downstream O2 reads zero
  174. Bigger tires help!!
  175. air bags
  176. Overhead counsel out
  177. Coolant leaking into #5 plug well, 5.4L 97 F-150
  178. 98 4.2 no start
  179. Ignition Troubles
  180. Intermittent low RPM misfire
  181. Clicking sound
  182. Figured its time
  183. Debating: replace engine, or sell truck...
  184. Cold weather rough idle solved finally
  185. 1997 2wd makes clicking sound in front end when off road....
  186. Header/Manifold Question
  187. 2002 f 150 charging light
  188. Transmission Cooler failure
  189. pigtail diagram
  190. 4.6 alternator caught fire now in limp mode
  191. Motorcraft FL-400s or FL-1A
  192. hello all returning member
  193. Rims
  194. How many 97-03 4x4's with under 100k?
  195. Whats the best lift
  196. No heat when it's below zero
  197. Radiator Fan Clutch Question
  198. 2001 Screw 4wd front end noise
  199. 1998 xlt 4.6 just quit
  200. need help fast
  201. Straight seat center console
  202. Need some advice
  203. 1999 intermittent blinkers
  204. Light bars
  205. Bad Vibrations!
  206. 2 gauge pods for 03 SCrew?
  207. Conventional Vs. Sythetic Oil
  208. No downshift when braking
  209. 03 f150 fx4 tire size?
  210. 4wd actuator dust boot
  211. Ultimate Coolant Riddle
  212. starter solenoid on firewall horrible noise!
  213. Good A/T tires
  214. I need advice ASAP, please.
  215. Air trapped in coolant system after heater core replacement?
  216. Broken Rear Window, Please help!
  217. Help, 97 F150 electrical just went ballistic!
  218. 98 starter relay click
  219. idk what else to do please help
  220. Mirror replacement
  221. How To Disable The FOB During Start
  222. Help!!!
  223. Engine switched off whle in reverse. No codes and I was able to start it.
  224. H9 Rear
  225. shocks
  226. 2003 with flickering lights
  227. intake problem
  228. Xlt Badge ReDo
  229. Need some AC help
  230. Marvel Oil
  231. Foot pedal pads
  232. Question about fuel pressure testing
  233. need help, new to trucks.
  234. adding keyless entry.
  235. Fuse keeps blowing
  236. Head sounds like bad power steering pump.
  237. 2000 f150 regular cab long bed
  238. Lope idle when cold start
  239. 4x4 Not Working, Have Questions About Diagnosing
  240. Question about 99 F150 differential
  241. 2003 FX4 Brake Issue
  242. blower motor
  243. factory ford lightning upper grill insert 01-04
  244. abs issues 01 4x4 4.6
  245. '02 F150 4x4 won't steer!
  246. Question about 4x4 Capability
  247. Sta-bil is safe? O2's, injectors, CAT's etc?
  248. 1997 F-150 Won't Start Reliably
  249. just another seat swap thread.
  250. Heater Core Replacement Mechanic Left This Off
