1997 4x4 randomly started using a lot of gas.
Old Mar 10, 2015 | 11:06 PM
PriorB0B's Avatar
I was on my way to work which is about 15 minutes away and I noticed that my gas gauge was dropping more than it usually would. I was a little under a full tank and I ended up with 3/4 by the time I got to work and about half way to work my check engine light came on. What could do this?
Old Mar 10, 2015 | 11:34 PM
If the CEL came on the first thing you need to do is read the codes. Unless you are in California most parts stores do it free, or you can buy a code reader on Amazon for 20 bucks. Post the number code, not what the Autozone flunky says it means.
Also post which engine you have.
