PDA
View Full Version : 1997 - 2003 F-150
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. 'Splain sompin' to me Lucy....
  2. Hard decelleration
  3. 99 F150 Oil leak
  4. Reliability for long trips?
  5. 8.8 to 9.75 driveshaft??
  6. Looking to buy 1997 F-150
  7. Starter
  8. motorvac
  9. Little fun in the snow and the truck was running like crap + got some main done
  10. Towing Mirriors
  11. 1997 F150 stuck in park
  12. spacers for front springs ??
  13. Vibration noise on 01, F150, sounds like the CC but...
  14. Cluster color change,
  15. Fog Light ?
  16. Preventative maintenance vs. Predictive maintenance
  17. Losing Oil Pressure
  18. HELP!! Truck won't start....
  19. Rebuilding 9.75 Trac-lock
  20. Need Some Advice with a might get truck
  21. Quick question - Tire PSI??
  22. Battery indicator Illuminated
  23. Switching to bucket seats??
  24. Wtb OEM nerf bars
  25. Lsd to posi
  26. Missfire - which COP is at fault?
  27. posi spiders same as open?
  28. New member
  29. Conversion 5x135 to 6x135
  30. Lift kit help
  31. how to figure out what spline axels i have
  32. Seat removal
  33. How to tell which bearing is going out?
  34. Wiring a Viper 5901
  35. Amp Questions
  36. 99 f150 build up questions.
  37. CEL help
  38. having some issues could use some outside opinions
  39. Too Good To Be True ??
  40. Keyless Entry Opinions and Advice
  41. biggest lift for a 2wd
  42. 3.55 diff H9 limited-slip in my 4.2L with 3.08 diff HELP
  43. Rough Country install questions..
  44. Dee Zee Bed Caps
  45. odd idling problem 4.6L
  46. 2000 F-150 4x4 off road pkg. back wheels slipping
  47. Just Broken In
  48. Tow mirror marker lights
  49. Recommend brakes / suspension
  50. Shifter strap
  51. Mice problem
  52. Confused= 03 factory air suspension?
  53. I made a boo boo...
  54. Oil pressure gauge schizo ?
  55. Where is the 4x4 control module?
  56. 97 f150 stuck in 4x4 PLEASE HELP!!
  57. Idea for a Liscense Plate
  58. long tube headers for 4.6 2wd
  59. new guy/?'s
  60. Still hunting FX4 whhels
  61. What I've been up to
  62. looking to buy new wheels this weekend
  63. heavy duty front bumper
  64. my truck has spark knoock why
  65. muffler remove
  66. Rear Headrests
  67. more exhaust problems
  68. 4x4 axle-shaft/hub. ??
  69. Pre 7/97 Headlights to later conversion
  70. Weird overheating issue
  71. New Aux/Fog Light Location
  72. need some help with mgp 97 f150 4.6L
  73. water Leak
  74. looking atbuying this truck to part out but now i dont know
  75. Engine Dies While driving
  76. Power Door Lock Actuator
  77. Looking @ buying a 98 scab for a parts truck
  78. Help diagnosing ABS codes 1198 & 1214
  79. Dome light issue need some help
  80. Towing with 5-speed
  81. Viper remote start on the way!
  82. i think it is stupid that ford did this that way
  83. Need help with 4x4
  84. Cleaned Up the truck
  85. How can i prolong the life of my truck?
  86. Truck is Old, but need to keep her running. HELP!!!
  87. Interior Lighting. Questions.
  88. rear differential leak
  89. 4.6 missing real bad
  90. 03 F15 KR Rear Door Handle Problems
  91. Fuel PSI requirement
  92. Fuel PSI requirment
  93. 1998 F-150 V-6 hard to start Cold
  94. broke a ball joint plus other stuff. pics
  95. Wanting Remote Start but have questions
  96. This may sound weird but?
  97. Need help, truck will not start, crank sensor?
  98. basic tune-up procedures?
  99. Help with problem diagnosis, banging engine
  100. fan and turning on points
  101. Climate Control Panel not illuminating
  102. Low Buck Mods for 4x4's
  103. My conversions......
  104. want help with lean codes, firing ,skipping ect........
  105. No oil pressure
  106. tires and rims for sale
  107. Differential Leak
  108. How To: Replace steering wheel '97-'03 F-150
  109. Wheels for Lightning with 2/3 drop???
  110. 98 f150 randomly shifting into 4X4 while driving...
  111. #4 Misfire, Not consistent.
  112. 2001 Ford F150 Lariat Supercrew led light help (Pix)
  113. help
  114. 1999 Ford F-150 Maintenance Schedule
  115. Programmer & Mafia??
  116. 99 Fog Light Switch Wiring
  117. Remote Starter
  118. wheel bearing going bad?
  119. lower rear end help
  120. Wierd Problem.
  121. Help! Overheating Problem
  122. Digital Climate Control Backlight
  123. Few pics of my ride
  124. Driver unlock wire color and location?
  125. Show me those 20's 22' or 24's on your S Crew 4x4's
  126. 1998f150 4.6 swap 19985.4
  127. Would this TSB cover me?
  128. DEPO Headlights w/Projectors
  129. ???? What to do now ????
  130. High idle and not up/down shifting
  131. Help already changed thermostat
  132. Name that piece
  133. Picture of my oem sparkplug 135,000 miles ROFL!
  134. How many miles is too many for a used F-150?
  135. 4.2-4.6 swap?
  136. 1997 4.2 engine swap ??????
  137. Just an FYI for anyone replacing O2 sensors
  138. Pictures of lower valence removed? 99-03?
  139. 4WD Package worth every cent
  140. I'm back!`
  141. stock '97 F150 4x4 needs ideas
  142. My 2WD F150 Transformation Thread
  143. Heat suddenly quits....
  144. illumination for a/c/heater controls?
  145. First Self Service
  146. So i need some help
  147. Few new shots
  148. Phoenix Chip?
  149. just got a set of 35" 16 5x135 need adaptor or trade
  150. '99 2wd f150 lift help
  151. Odometer and Tripmeter not working
  152. Rear end whining nosies
  153. Digital vs Knob Heater Control unit
  154. minor misfire 1997 f150 4.6
  155. 98 2wd lift?? need help
  156. Mind boggled wierd vibrations?
  157. positive ignition signal
  158. Help a brotha out
  159. 4.6 to 350RWHP
  160. help
  161. Cold draft coming in from passenger speaker hole
  162. 1999 F 150 5.4 with starting problem
  163. Dash rattles and sqeaks
  164. Is my Therostat bad?
  165. interior light
  166. billet grille for 03screw
  167. How long can I let my power steering whine?
  168. Strange noise? No resolution.. Please Advise!
  169. Lift and Tire Help,Pleaseeeeeeeeee
  170. Sticking in OD? ('03 5.4L FX4)
  171. Awesome..... or not
  172. custom making bumpers
  173. Engine locked up
  174. lift kit photos
  175. 2003 4.2L V6 system lean?
  176. 4.6l or 5.4l
  177. Need help finding a taller console
  178. Engin problems
  179. What to do?? 97 f150
  180. 97 4.6 Rebuild or Swap?
  181. 99 ford f-150 6 cyl 4.2
  182. 4x4 takes a while to engage
  183. Just a friendly reminder
  184. 1997 engine swap
  185. 4x4 "knob lights" blown?? or never there... hmm
  186. what would cause this
  187. First Time Posting - MAJOR ISSUES
  188. anyone with a programmer/chip
  189. gas mileage and lift ? on 99 f150
  190. Ciol Pak
  191. Spark plugs changed, now what? Still not fixed...
  192. Screeching Loudly in reverse only
  193. factory in dash 6 dish changer
  194. Ex cab shaved tailgate
  195. Little bump big clunk first 5 miles only???
  196. Buzzing noise
  197. Can Anyone Offer Some Help
  198. DTCs
  199. I need some opinions on cammin my 2v 4.6 please..
  200. 6.4L Winter Front On F-150?
  201. Bent Bumper
  202. some pics of my truck
  203. Weird flopping sound on my driverr side
  204. Loss Power
  205. gargling sound under hood
  206. mpg/lowering
  207. coolent leak. help
  208. 97-03 f150 steering wheel swap to 06-11
  209. Heeeeeeellllllllppppppppppp!!!!!!!!!!!!!!
  210. 1998 4.6 4x4 a/c clutch frozen up
  211. Self rigged custom DRL setup on 99F150, Please assist
  212. Fried the 4R..
  213. V8 running rough!
  214. fog light question
  215. F150online Stickers
  216. help finding used 2wd lift kit
  217. Lower valance help needed.
  218. 4.63L p0305 problems **HELP**
  219. I have 2 Questions about my 03 F150 KR
  220. Security System Problems
  221. Thought I would say hi to my big brother trucks
  222. Airbag Fuse = Heater Motor?
  223. 2001 Driveshaft Question Position question
  224. wiper problems
  225. help f150
  226. please help!!!!!!!!!
  227. Heater Barely Gets Warm
  228. '01 F150 - location of truckbed (drain) holes?
  229. hard start in extreme cold
  230. Crankshaft out of a 2001 5.4L?
  231. Remote Start & Alarm in 98 f150
  232. wet carpet
  233. Black specs in coolant
  234. Axle Help
  235. Spare tire assembly
  236. Wrecked my truck....
  237. 01 Supercrew 5.4 Cranks but will not start
  238. This is how the black Lightning corners should look
  239. 4x4 Went out and this is what he charged?
  240. 2002 F150 needs new engine want 4.9L is it possible
  241. Wanted FX4 wheels
  242. Removing the bed
  243. DPFE (code P1405) question
  244. 97 - 03 Factory Step bars Help
  245. how to verify i have 2 Master pats keys? for remote start bypass pkall
  246. Transmission Flush?
  247. so its been a while since my last post, but heres the truck now!
  248. Several problems and codes
  249. Horsepower on 4.6 V8
  250. My Tan Buckets/Console for your 60/40? Phoenix area
