How long can I let my power steering whine?
Old Jan 28, 2011 | 05:44 PM
tracka96's Avatar
I've got the power steering whine, changed the dirty fluid today with no change in the whine, didn't really expect any, Just wondering if the whine can go on for a long time without pump failure. Tracka96
Old Jan 28, 2011 | 07:12 PM
Raptor05121's Avatar
How many miles? If its really bad you might want to get ready for it to quit. But then again Ford's PS systems were always a bit on the loud side
Old Jan 28, 2011 | 07:39 PM
Red02FX4's Avatar
Expect some whine just after power steering service till all the air gets out of the system. Turn the steering wheel left to right (it should get louder when doing this) to purge some of the air. If it continues after a day or two... get a new p/s pump... purge the system again... and be done with it
Old Jan 28, 2011 | 07:49 PM
rednutbow's Avatar
Originally Posted by glc
I suppose you could use a turkey baster to suck out all the PS fluid you can and replace it with synthetic ATF. I've heard that this can quiet the pump down.
Quoted glc in another thread
Old Jan 28, 2011 | 10:28 PM
tracka96's Avatar
Here's an olf thread I googled up:
https://www.f150online.com/forums/ot...se-normal.html
Old Jan 29, 2011 | 04:58 PM
Howies_effie's Avatar
I thought my 2003 had a PS pump whine, but it was a bad bearing in the alternator.
Admittedly, the Ford PS pumps are prone to whine, but in my case a new alternator quieted the truck down nicely.
Old Jan 29, 2011 | 05:14 PM
jbrew's Avatar
Mine was a little noisy a few years back. I pulled the line and flushed it out good (don't let it go dry). - Work in some Amsoil, run a little good stuff thru the system , reconnect the line then top it off w/Amsoil Trans fluid or something as good as. Mine hasn't made a peep since. Doesn't have to be Amsoil, - just something as good.
That's the best you can do for it. If it's not to far gone, that will quiet it down for yuh.
