Heat suddenly quits....
Old Feb 1, 2011 | 07:17 PM
mcolford's Avatar
Heres the run down on it:
Im plowing snow this morning in a small parking lot, as im pushing snow into the pile, the heat suddenly quits, and feels like the a/c is turned on. It will not go back to heat. All controls work (vent/floor/etc.) but the heat doesnt work. Im at a loss for words, and my local Ford dealership is.... well we wont talk about that.
I need help quick guys, im sitting in the middle of a blizzard, and no heat ssuucckkss.
Old Feb 1, 2011 | 07:32 PM
Raptor05121's Avatar
check water level
Old Feb 1, 2011 | 08:02 PM
hunterjh's Avatar
^^x2.....mine would do that and it would be the water level as well
Old Feb 1, 2011 | 11:44 PM
Mine had the same problem. No heat when accelerating (waler sloshes back and doesnt reach heater core) but when smooth or slowing down it fills it up
Old Feb 2, 2011 | 01:23 AM
b2therad's Avatar
I was going to say check water level, or maybe your thermostat is checking out on you.
Old Feb 2, 2011 | 11:32 AM
4wd150's Avatar
off topic but hows the 150 do plowing?
Old Feb 3, 2011 | 02:23 PM
mcolford's Avatar
It does real good plowing. I have 400 or so pounds of sandbags in the back, and run a 7'6" plow, and it does pretty good. Gas mileage blows, but I made a killing off the storm yesterday, so Im not too upset.
Back onto the truck topic... Suddenly my heat came back for a minute, after 12 hours of plowing with no heat. Then it left again. This morning it has been off and on...
Im lost.
Old Feb 3, 2011 | 02:52 PM
biggrey's Avatar
Are both of the heater core hoses hot?
You could have a problem under the hood, water not getting to the heater core. Or you could have a problem in the cab, air not going through the heater core.
Maybe if the blend door was broken, the impact of hitting the snow could have closed it and cut off the heat?
Old Feb 3, 2011 | 03:08 PM
mcolford's Avatar
Both hoses are hot to the heater core. Im just not sure, as the heat randomly works. I would think if the blend door went to ****, it would be completely gone.
Old Feb 5, 2011 | 12:27 AM
mcolford's Avatar
UPDATE: My heat has suddenly came back to its normal state. Im thinking just a random air pocket got to the heater core. The million dollar question is how did I get a pocket in a system that doesnt have a bleeder valve?
