Rear end whining nosies
Old Jan 31, 2011 | 11:17 AM
RHood's Avatar
2000 F150 4.6 SC auto
I am hearing a high pitch whining nosies coming from the rear of my truck any ideas? It happen around 35 to 45 mph but at highway speeds I don't hear it I put the truck in neutral and coast and still hear it. It just started about two weeks ago what should I check for?
Old Jan 31, 2011 | 11:54 AM
Enemy's Avatar
Could be bearings, differential, or a midget if you've run over one lately. I would lift the rear of the truck and spin the wheels by hand to determine where the sound is coming from.
Old Jan 31, 2011 | 06:38 PM
Toyz's Avatar
Check your rear axle code to see if it is a LS differential. If so, it needs new fluid and friction modifier. If not, start with a fluid change and go from there. But check things out first, could be U joints if its more of a squeak.
Old Jan 31, 2011 | 06:54 PM
jimanderson's Avatar
See if your bearing seals are gone. When my bearings went on my Mustang there was a good layer of fluid where the drive shaft dissappeared into the tube.
Old Jan 31, 2011 | 07:05 PM
RHood's Avatar
In 2008 at 73,746 miles had Differential Service Pinion seal replace & Mobil 75/140 Sinthetic Oil truck has 97,845 miles on it now ?
Old Jan 31, 2011 | 10:10 PM
Carcrazygts2's Avatar
Sounds like gear noise. If it was run low it could have scarred up the gears and causing them to whine. I just had the same problem a month or so when someone installed a rear axle seal backwards...
