Spark plugs changed, now what? Still not fixed...
Old Jan 25, 2011 | 08:17 PM
radsmachine's Avatar
Hello guys, I'm new here and at at the end of my rope, kinda... My 2000 f150 (79 k miles) started running rough a coupla weeks ago and the service engine soon light came on. .I put a diagnostic thing on it and it came up "po308" misfire on the number 8 clinder, right? took it to the shop today, paid a guy 80 bucks to replace the spark plugs and guess what? The thing still acts funny when it goes into overdrive, kinda shakey and loss of power, but no service engine light. should I replace the fuel filter next what? Thanks for reading and I'll thank you in advance for your opinions....rad
Old Jan 25, 2011 | 08:34 PM
Toyz's Avatar
He probably cleared the pcm after the plug change. If the misfire continues, it should come back...
If its the oem filter it wont hurt to change it. But I would look at the cop, maybe switch it with another cylinder and see if the misfire moves with the cop. Or wait till a CEL comes back.
Old Jan 25, 2011 | 08:40 PM
Uhhh, can I have that in english?
Old Jan 25, 2011 | 08:41 PM
drove it thirty or so miles today, the service engine light did not come back on...
Old Jan 25, 2011 | 08:45 PM
jbrew's Avatar
That was perfect English. What do you need defined?
Old Jan 25, 2011 | 08:46 PM
Toyz's Avatar
Low grade misfires normally show up under load or right after the shift into overdrive. So it sounds like its still misfiring. If you can get it to misfire numerous times, look for the Check Engine Light to either flash or come back. In other words, wait for it to start stumbling, keep light pressure on the pedal and keep it misfiring as much as possible. Something should come up. It was either your plug, cop (coil on plug) or an injector causing that misfire you had "p0308" and since he only changed the plug, it could still be either the cop or injector. More than likely a cop though. They have known to fail.
Wait... what engine do you have? 4.6 or 5.4?
Old Jan 25, 2011 | 08:59 PM
Thank you toyz, think I should replace fuel filter? oh, 4.6 stock.
Old Jan 25, 2011 | 09:10 PM
Toyz's Avatar
Then you most likely have coil packs (2 coil packs, one for each bank... with plug wires), not coil over plugs (individual coils over each plug...no wires). Either which, is still a possibility its the problem of the misfire. Change the fuel filter for good measure, its needed. Might not be your issue but it needs changed.
Old Jan 25, 2011 | 10:14 PM
jbrew's Avatar
Originally Posted by Toyz
Then you don't have coil on plugs, you have coil packs. It's possible there is a bad wire for that cylinder or possible a bad coil pack (not the whole coil pack has to go bad, it can have a single cylinder misfire). Change the fuel filter for good measure, its needed. Might not be your issue but it needs changed.
Toyz, - some 4six engines has CoilOverPlug, some had Pacs. Not sure why , but I've come across both for the 2000 model.
radsmachine - Does your ignition system include plug wires ?
COP = No wires.
Coil Packs = plug wires.
Old Jan 25, 2011 | 11:04 PM
Toyz's Avatar
Fixed
Old Jan 29, 2011 | 10:48 PM
I don't know which it has. I'm gonna ta ke it back to the shop and have them replace it all. coil packs and plug wires if it has them....I'll check back later...Thank you for all your replies to my little problem. rad
Old Jan 30, 2011 | 02:37 AM
Carcrazygts2's Avatar
jbrew- the trucks that have COP's are all PI trucks..
Old Jan 31, 2011 | 07:33 PM
Ok, found out that the truck has a coil pac on each spark plug, no wires. I told the guy to replace the number eight cop and the fuel filter... I would'vr had em all replaced but they are almost 50 bucks each and I'm not a rich man. We'll handle em one at at the time. I'll post back when I get done and update....later, rad. Also I'll post pics...
Old Jan 31, 2011 | 11:42 PM
You can buy a whole set of 8 coils on Ebay for about 80 bucks.
Old Jan 31, 2011 | 11:59 PM
jgger's Avatar
Toyz and Jbrew my 2000 expy has the 4.6 with cops, don't know why they did both. Just some info.
BTW what is PI, I know it's 3.1416 but I mean on the motors.
