Help a brotha out
Old Jan 29, 2011 | 10:46 PM
Enemy's Avatar
Help a brotha out
I want to lift my 2wd 00' F150 ext cab. As far as I can tell it still has the stock suspension which seems taller then most other 2wd but I still want it higher. I want to do this for as little $$$ as possible (under $100 :. I want it at least 2" taller and for it to sit level so I need pics, links, parts if your selling any etc.
Pic of the subject in question.
Old Jan 29, 2011 | 10:51 PM
Enemy's Avatar
What companies make 2" coil spacers?
If I can't fine 2" can I run 1" coil one on top of spring and another one under?
A friend told me about something that is used to lift a truck, you insert it between the coils on the spring and it expands them which gives the truck the lift. Anyone heard of these?
Old Jan 29, 2011 | 10:56 PM
jbrew's Avatar
Fill some beer cans full of Ready-Mix W/3 oz's epoxy per can (for a binder). Let it harden. Slice ,dice and port. There's your body blocks.
Threaded rod is cheap. That and a crap load of nuts and washers for body bolts.
Should be within budget.
Old Jan 29, 2011 | 11:02 PM
str8t six's Avatar
daystar makes a leveling kit.
are you talking about spring stiffeners? those are for like race cars.
Old Jan 29, 2011 | 11:03 PM
str8t six's Avatar
here is a 1.5 spacer
http://www.suspensionconnection.com/...KF09105F1.html
but i think somebody make a 2.5" spacer also.
Old Jan 30, 2011 | 10:29 AM
dirtroadrider's Avatar
Truxx makes a kit that goes to 2.5 but if you go that way,I don't think it would alignment numbers would be pretty.They say and 1.5 to 2 inches is the most that you want to go.
Old Jan 30, 2011 | 12:56 PM
Enemy's Avatar
does someone make a 2" coil spacer?
Old Jan 30, 2011 | 03:05 PM
b2therad's Avatar
daystar and springtech
Old Jan 30, 2011 | 03:10 PM
Veteran: Army
2 inch body lift...
Old Jan 30, 2011 | 03:13 PM
Veteran: Army
and get me some westing sport tubes so I can take off these 4X4 running boards off of my green truck
Old Jan 30, 2011 | 04:02 PM
jbrew's Avatar
Are you guys staying under $100, - shipping included?
Old Jan 30, 2011 | 06:12 PM
alex7191's Avatar
ive got 2 inch lift coils in the front. been pretty happy with them for a year now. you dont wanna stuff anymore than 2 inches in there
Old Jan 31, 2011 | 09:35 AM
Enemy's Avatar
Link to where you bought them from?
Old Jan 31, 2011 | 07:04 PM
alex7191's Avatar
http://www.roughcountry.com/ i think they were around $150 though
Old Jan 31, 2011 | 08:10 PM
Lightning Expo's Avatar
Get the metal ones on ebay. Put them on the bottom of the spring. They work great only like 40 bucks. Then you have alignment for like 60-80.
