Rebuilding 9.75 Trac-lock
I tried searching and couldn't find anything. Has anyone put new clutchpacks in the lsd of a 9.75? I've got 150,000 miles on mine, and it doesn't do a whole lot anymore. Is it as easy to do as an 8.8?
No its no where as easy as the 8.8... You'll need a spreader to spread the axle spider open to install the other 2 spiders.. The real problem is the springs behind the clutch packs get weak. I have done this numerous times. You'll need to replace the tension shims behind the clutch packs then use one of the old shims on the backside of the tension shim..
