Transmission Flush?
Transmission Flush?
I went to a local tire/auto care center my family has been going to for a whil and I got a quote for regular maintenence on the transmission and the service manager told me not to have some fluid and a filter change but he recomended a full transmission flush? is this a good route to go or not? i think he said they would put Valvoline transmax fluid in it which he said is better than ford motorcraft tranny fluid, is this also true or am I being mislead? thanks for any info, it is much appreciated.
It really depends on the past maintenance on the transmission. If the fluids have been changed regularly you could probably get away with a flush without any damage, but if the fluid has been neglected I would just do a pan fluid change. I have not heard of any trans flushes in neglected transmissions that didn't eventually lead to failure.
Personally I would stay away from it.
i wouldnt do it. alot of people that do the "flush" (as apposed to a exchange) have their trannys go out because it loosens up some buildup and clogs the trans. i would just drop the pan and change the filter.
Using a machine to do a fluid *EXCHANGE* is fine. Do NOT let them use any flushing chemicals or use any kind of machine that doesn't simply use the tranny pump to do the work with the engine running. Valvoline is good fluid, but I don't think it's any better than Motorcraft. Whatever fluid you use, make sure it meets Mercon V specs.
i did a trans flush at work on my truck. allegedly when i bought it the previous owner had a huge 100k service and i just flushed it and filtered it at 163k and its been fine ever since.
im not sure about what the previous owner did but ive had the truck since it had 125000 now it has about 165000, i added a little bit of ford tranny fluid to it when i did the body lift cause i lost some the truck drives and shifts fine so do i really need to do anything to it? and if i do you guys recomend the filter and fluid exchange with all motorcraft stuff? thanks again.
