Engin problems
Old Jan 26, 2011 | 09:52 PM
kossford's Avatar
Engin problems
I changed my thermostat in my 97 f150 5.4 and now the truck is running funny missing chugging and loss of power and friend said it was coolant fouling out a plug or two but not sure any help would be greatful on if this is the problem and how to fix thank you.
Old Jan 26, 2011 | 11:03 PM
Toyz's Avatar
Reason you changed the thermostat? Overheating?
Old Jan 26, 2011 | 11:09 PM
ParnAZ's Avatar
DTC's please...Shot in the dark but if the thermostat housing is leaking coolant then perhaps some plugs are wet? DTC's please...
Old Jan 26, 2011 | 11:49 PM
Red02FX4's Avatar
If the truck ran fine before the thermostat change, I would suspect an air bubble in the coolant system, though I don't know why that would create a miss. Does your friend actually know that coolant might be fouling the plugs? What evidence?
Old Jan 27, 2011 | 04:56 PM
Air in the coolant, overheating, fail-safe operation.
Old Jan 28, 2011 | 03:25 AM
WholeLottaRosie's Avatar
Did you unplug anything while working? Did you get antifreeze on any of the electrical components? Most have an o-ring inside, but you could have fluid trapped in one of the connections.
Old Jan 28, 2011 | 03:29 AM
jbrew's Avatar
Coolant ran down the head and filled the plug chambers.
So blow them out, that will happen if your not careful.
Old Jan 28, 2011 | 06:16 AM
Veteran: Army
#1 why did you change the thermostat??
#2 did you replace it with a lower temp thermostat???
Old Jan 29, 2011 | 01:18 AM
kossford's Avatar
Thanks everyone for the help i will pull the plugs and blow out cylinders and the reason for changing the thermostat was it was stuck open and heater was not getting very warm.
