View Full Version : 1997 - 2003 F-150
- 02 Supercrew Subwoofer Help
- Towing a horse trailer?
- Front End Noise on a 2002 FX4
- tailgate
- Cranked t-bars and wantin 33's
- Lightning Brake
- Accel Coils Not Compatible with OEM?
- Code 171 and 174 HELP!
- radiators
- 285s or 295s Is stepping down worth saving the money?
- Misfire in 1 and 6 untill it reaches operating temp
- 2003 f-150 shock replacement
- Trailer wiring
- P0302 Misfire on #2, 4.6L 2V
- my truck is a flaming hot pile of trash and i want to light it on fire!
- Does your factory spare match?
- Lifter/tappet
- High pitched squeal
- fx2
- New Toy, bye bye Mach, trucks all fixed!!
- Headers??
- help!! eaton vs track lok??
- Front Bumper damage
- My truck's exhaust
- Soft Brake pedal with hiss. Brakes still work but not 100%
- 2002 ,5.4L, 175K PATS flashing plus intermittent rough idle
- Need a engine
- 97 f 150 dash
- Need help/suggestions
- Programming strangeness for plus size wheels / tires
- I smell antifreeze :-(
- 285 50 20 on 02?
- 97 F150 4X4 SC exhaust suggestions
- 2002 F-150 w/4.6 issues @ 150K
- Bearing Preload Question - Please Help !!
- 03 Pulling Semi off the guardrail in snow and other videos
- Parts help
- Engine almost dies
- Pro Comp wheels
- 1997 ford f-150
- front clip
- Truck verse Car
- Spark plugs
- blower motor
- It was so cold this morning my turn signals didn't work
- 2002 f150 mileage/tranny ?
- Squeaking front suspension
- 97 4.6 lariat 4x4
- 2000 F150 Door Electrical Problems
- Spongy brakes....
- Heater treater?
- n-fab light bar
- Truck Vibration problem
- 2003 4.2L p1131 and p1151
- 99 F150 Automatic won't **** to 1st on the column
- Dead power point outlet
- Need help with price$$$
- Fuel Pump
- Heater core change question
- Turn signal fuse blowing
- Urgent- will these gears work?
- how to program prostart remote starter
- Amp Rack and Dual 10" Alpine R install
- Extra Battery Install - How to
- Big 3 + Starter upgrade with extra battery
- 2001 M112 Supercharged V6 Build
- Vacuum Hose Trouble
- 302 code on 97 f150 with 4.6
- 99F150 terrible in the snow?
- Camshaft syncronizer install problems
- 99 F150 Biggest Tire Can Be Put On?
- 2002 XLT Leveling kit question
- Modular 5.0 Swap
- What shocks to use with torsion bar crank...
- Finally swaped my front end 99+ pics
- Motorcraft Wire Set Prices
- 2003 F-150 Shudders on Acceleration
- life expectancy of ball joints?
- how do i Add a rear center console to a super crew
- Used motor Reference
- 98 f150 wont move
- Leveling kit on top of suspension kit
- Airbag code 27
- Front Window Leaks - Somewhere
- Partially Convert '03 XL to XLT, am I crazy?
- Bench Seat Center Console
- Same problem as NoHeatDave except
- No fuel pressure
- 2001 f150 4.6L v8 trinton motor 8th digit vin w
- 01 Screw and Expy front door shell? Are they the same?
- Cut out flares
- edge programmer issue, or something else?
- 2K F150 5.4L Plastic Engine Cover
- bigger tires
- F150 Rear Lowering...
- Wil a 2002 F150 4.6 go in 1997 with same engine?
- Stock Radio on a 97f150/Passenger Window!
- 99 F150 4.6 Seat Belt Dinger
- 97 F150 No 4x4 shift on fly at interior
- window Issues and more
- Cross shaft bolt in rear diff broke. Help!!!!
- shock reccomendation
- 2000 no 4wd.. What is this??!!!!
- Cheapest and easiest way to clear 33" tires and 17 or 18" wheels
- what's the difference between the 4.6l in the f150 and the 4.6l in the Mustang?
- sputter after changing spark plugs
- Install fm direct antenna in 1997 ford f150
- Identify That Noise
- Gas Pedal keeps sticking!!!!
- Damn #4 COP!
- Lost ignition key
- Turn Key Suspension Help
- no hornn no cruise no compass
- Help! cylinder 3 misfire
- Door Auto locks
- Exhaust manifold question
- auto lights, turn off when driving
- Cummins swap???
- Factory Oil
- Help! Electrical(?) issue
- Odd engine rev question
- transmission???
- 10 mpg, cold weather hard starts, missfire at idle????
- Does a 1998 f150 have ABS?
- How do you take the front bumper off a 1998 f150
- 98 f150 lost most electrical power while driving but kept ruunning
- 2000 ford 150 water in my ignition coils
- NEED HELP!! Confusing Problem.... For me anyway
- need seat belt buckle
- 2000 temp control lights??
- OEM Mexico grille
- Before and After
- 03 supercrew stuck in 4wheel low
- 2wd '02 F150 Screw WHEEL AND TIRE HELP
- IAC problems 2001 F150 5.4 Supercrew
- 2001 5.4 pinging
- COP's
- ATF+4 full synthetic in transfer case?
- Newer Expy throttle body cover mod
- 01 f150 heater core fixed but now have a crazy sound
- Coil pack question
- Did a little 4x4 trip. Really impressed
- Weird Power issues (no window, wipers, radio, 4x4, and viper not responding)
- Need help finding pink/yw & pink/grn pw door lock wires for '97 alarm install
- Tired of Wheel Shopping...
- 1997 Wheel/Tire help wanted!!
- Blend door R&R
- 2001 f150 won't start (I know. Another one!)
- Need heater switch help
- Front grill Switch
- 2000 f150 pats question
- Spring Codes
- What Gears?
- Shifter won't go into park!!
- help with electric fan conversion needed!
- 99 F-150 making myself and the dealership a little crazy
- Coolant leak under the driver's side of the engine.
- Back in a F150 (2000 Harley project)
- Transdapt #1127 Oil Filter Adapter Question
- Is my 99 all metric fasteners or mixed?
- Limited Slip or Open Diff?
- Rear end issue need help
- P0125 code and ABS Sensor light - ok to drive?
- Shotty Mechanic
- 2002 Screw
- Charge light came on today
- in search of tranny replacement advice
- 00' 5.4L 4X4 dies after about 20 mins.
- loud noise coming from air filter area
- Think I toasted my cat converters
- new (to me) headlights
- VIPER VSS3000 Remote Start for 2000 King Rancher
- Nasty oil leak around my filter somewhere
- 99 body or suspension
- Need Help, Installed an 2006 4.2L into my 1998.
- 4wd Shift assembly
- 2000 4wd ABS sensor/harness
- 1998 F150 4x4 Mark III
- Need tire advice/help!
- could really use help with diagnosis, heres my symptoms
- spark plug diagnosis
- Engine or Trans.?
- Winshield wiper comes on randomly.
- drive and overdrive gone
- 2000 f150 front end on a 1997
- IMRC Fixed, Next problem, please advise...
- Overheating
- Undercoating Question
- Blame the wife on this one!
- Water leak into center of cab
- Help I can't figure this out
- Engine Oil Weight Question
- ABS issues NEED HELP!
- Bed Side Replacement
- Misfire and lean codes
- More Power Please!
- SVT Lightning Fornt bumper
- Just bought a 1999, what do I check for?
- 98 Ford F180 4x4 light stays on
- heater problems, need some help!
- 9.75 rear end passenger side seal keeps leaking
- electric fan turn on temp
- bod swap: ext cab to reg cab
- air bag light 1997 4.6 xlt 2wd
- Best possible gas mileage
- Idle surge 2003 4.2 5 speed
- New head lights installed!
- A/C going hot when on high
- front bumper ptm picts?
- 302 swap into a 2000 F-150
- bed weight
- Help plz -___-
- Whats your favorite Mod done to date?
- Need help with finding wheels.
- Levelling kit or not!
- Weird problem(s) with my '98
- 4.6 to 5.4 swap notes clarification
- Whoop Whoop! hit the cl jack pot last night!!!!
- Need a little info about F150 7700
- very odd little idle problem
- New Toys!!
- 2002 Valve Cover Gasket Replacement - HELP!
- going old school to older school
- Really hate my truck right now
- I have a creaking sound when I hit a bump
- Whats a good price for a 03 Harley F150
- Transmission Fluid
- Should I plastidip my wheels?
- No Turn Signals or Flashers
- 2001 5.4L No Start
- Squeaking Wheels
- Does anyone make fender flares for the 1997 Flareside F-150?
- 1997 Ford F-150 Flareside Stock Mudflap Removal
- 2002 Ford F150 4x4 shifting problems
- I'm new and I got my first Truck
- '03 Gas gauge question
- My 2001 Ford F-150 7700 Series 7-lug
- 97 f150 transfer case stuck in 4low..
- Stock tires with 2" level pictures? (4x2)
- Intermittent and random knock in driver front wheel area....
- No heat in 98 F-150
- weird idle
- o2 Sensors
- silly f150 mirror question
- Custom Switches?
- a little before and after
- Strange Noise
- looky looky what i got back after 4 months!
- 2001 f150 4.2l v6 engine chatter under load
- GOTTS mod and other goodies!!
