View Full Version : 1997 - 2003 F-150
- engine start problem
- 03 F-150 V-8 Oil Cap/Yellow Crap
- heated mirrors
- Bolts for the 5.4 engine cover
- Sounds like a bad wheel bearing
- About to go insane!
- Remote start issues with factory security system
- 1997 Vehicle Security System white and black wire?
- Limted slip
- I'm New here... 03 Heritage
- tran on 2000 f150
- Questions on Timing???
- I'm New...and closing in on 100k
- Any Wheel sugestions???
- antifreeze seeping in oil pan on a 4.2
- sct 3015 for adjusting tire size question for 97-03 trucks
- Took the SVT headlights off, added new HL, and a set of nerf bars
- would you buy a truck with 200,000 miles
- Narrowing down the problem - have a few questions.
- whose got the highest miles?
- whose got a lifted reg cab?
- high miles?
- Tailgate Net
- Truck advice (5.4 reg cabs)
- '03 F150 with Extreme vibration in drive.
- Lowering Fuel Tank???
- 5.4 questions
- To do list
- Catylatic converter removal
- What is this wire hanging down? pics*
- If you have re geared, where did you get your gears?
- 2002 f150 7700?
- Help>>...99 4.6 bad gas mileage
- Been Awhile
- Power Steering Problems
- ABS messed?
- New Heads, Tails, and 3rd
- Found a 4x4 5.4 '99
- odometer not working
- random misfire
- Seat belt replacement question
- Cylinder order
- Little bit of rust..
- odo/tripometer stopped rolling
- bad situation, but ok result in the end
- Passenger door light cover
- gearing for a 1998 f-150
- replacing heater core
- 4 cats...its time to go bye bye
- ive many clean trucks
- Just replaced my door lock actuator..
- Firing up an 8 year old new 2004 5.4 crate motor
- 2001 F150 OEM cat system
- Supercrew totaled.
- lifted on 33s
- LED's under door frame
- New guy
- wiring question
- Blower moter works intermittently
- maf sensor
- Will it work
- 2002 sc heater
- 97 f150 not starting
- would you trade in the truck scenario
- My truck wouldn't start last night
- Efans
- whats your rpm's?
- 03 f 150 coolant leak
- Torx Bolt Size
- minor lift and upper control arms
- Suggestions needed please...
- Need Help with torsion bar questions
- Rear Axle/ Differential
- cant get head rests out
- Coolant pouring out
- New Front Clip
- 1999 F150 5.4l issues
- I've given in.... I'm asking for help..
- Dome light stays on
- Long Time Since i have been on here! new problems
- Body Lift... Yes or No?
- A Simple Transmission Fluid Change turns ....
- 99 f150
- fuel filter/beer help...
- More Power!!
- 03 F-150 turn signal issue
- 2001 F150 transmission problems...?
- Anyone running 16" XD Bullys
- '97 4.6, p0153, st ftrm2 % = 53.1 (!) (?)
- 5.4L 2002 #8 spark plug need help asap
- Another 150 won't start. Please help! (Long description)
- Steering wheel movement/wobble...
- How rare is this combination?
- Anatomy of a 5.4 COP
- Staring the upgrades
- Lifted 97 F150 with stock tires and rims speedometer off?
- 2003 F150 Heater Blend Door Replacement
- Am I gonna have broken spark plugs?
- Wont start after Heater Core Replacement
- replacing ignition cylinder key lock on 1997 f150
- headlight bulb replacement
- total loss
- tach intsall q's
- Dyno?
- 1999 4.2 f150 Ticking and hesitation
- Door/bed replacement?
- Grey Wiring Harness?
- Build sheet
- 1997 headlight problem
- Give an old friend some love
- finally I have a/c
- help help my 03 4.2 v6 is mising so bad that will not run
- 2001 Lariat Keyless Entry Code
- 4.6 Zero compression after helicoil...
- three from ok
- Just a quick thank you
- what headlights for my truck?
- Shock Question
- 97 f150 4wd wont disengage
- what parts are interchangable? 4.6 & 5.4
- 2000 F150 heated mirror conversion
- rear diff oil...
- hesitation when put into gear?
- Help!!
- What is this called?
- Overhead Console
- Suspect failed brake booster, looking for confirmation
- Ford vs GMC
- 2001 screw rear differential fluid change
- 2001 5.4 p0174
- Lol Rear Shock Removal Fail
- No park lights
- '01 F150 XL 4.2 ----heater core test
- Starting Issue
- 4x4 binding and pop
- Tranmission Issue?
- New guy in town
- New emblems??
- steering wheel swap
- Starting problems- starter/solenoid issue?
- Purchasing a 2000 f150 - what to look for??
- Update on the truck!
- 4WD not engaging
- Need help with emissions
- 4.10's or 4.56's?
- A/C Line
- Flex-a-lite Efan #270 kit installed
- Door Lock
- J mod,valve body, or Trans go?
- Which headlights?
- 2002 9.75 Bearing questions
- YES or NO, Cab lights
- 2001 Mod questions, thoughts
- 2001 F150 5.4L Issues
- My truck won't burnout anymore
- Pressure of oil
- no heat in wisconsin sucks
- coolant pissing out of bolt on front of intake
- All windows fogging up
- coil blowup?
- Coolant flush
- 2001 F150 won't start
- pics please
- lift opinions/pics?
- Need help :o
- Installed the MadEnterprise Valvebody...
- 01 ford f-150 harley 5.4
- pcv elbow collapsing
- Elextrical-hook up accessories
- Brush Gaurd Ideas
- What is this and where did it come from?
- Ticking Noise
- 4x4 Club?
- Condensation on the inside..
- 1999 f150 4.6l miss
- rocks thru inrake
- $12 LED bar
- How to remove rear ABS sensor?
- Little bit of rust??
- Whats your next Mod to-do List?
- Weak door locks?
- Blend Door
- Help with suspension lift
- Help! Hum and vibration
- 4.2 manifold
- 4X4 Clunk
- 2003 Ford F-150 Lariat 5.4 problem
- Patman Dash Bubble
- My Truck
- Thoughts ?
- Easily accessible Power and Ground wires?
- All WNY truck owners look here!
- po171,po174codes
- 2003 F150 2X shock question
- What is sensor on gas tank?
- Well !!!!
- Front Bumper Gap Fix?
- Slight whine from rearead under power...
- tomthumb
- Embarrassed..
- 2001 Screw Lariot 4x4 tail lights
- Intake leaking???
- new user 1999 f150
- Front sway bars 2wd vs 4wd, same OEM?
- Feeler: 2000 Ford Expedition Eddie Bauer part out
- Keyless Entry Clarification....
- Got 35s put on and Lightning headlights
- Headlight headache
- cylinder 5?
- traction bars mounted!
- sunroof / moonroof deflector
- 9.75" open differential
- newer 4.6 swap into a 97f150
- Replaced abs pump, now light on
- What does an analog odo look like?
- Truck pics finally!
- Steering Wheel
- New computer install assistance
- rear main seal
- not sure if this is in the right spot..
- Fooooord Problems
- MB Motoring Torque Wheels
- Need Help
- using over drive properly
- Misfire Maybe
- 03 5.4l Wiring from EGR DPFE sensor
- Horn Question
- 1.5" or 2" spacers?
- Need help engine doing crazy things
- torn rubber hose stuck around spark plug.
- Steering Wheel cover
- Gear change other add-ons for hp and torqu?
- Winch set ups!
- Lift questions.
- Anybody have pictures of truck with level kit only and 35's???
- 1997 F150 Problems with everything
- 1997 lariat to 2004 heritage?
- 1999 f150
- Dupont paint codes?
- Now power to 4x4 relay,bad GEM?
- Trying to lift my 02 f150 2wd
- Please Help!? Can I fit 33's with 20's on a stock 2wd 03 F150??
- Roll bar finally done
- Undercoating/painting Wheel Wells
- how i mounted my gps
- Input on trade: F150 to Powerstroke
- FREE v6 motor mounts
- 4r70w shiftkit,J-Mod DIY???
- New Truck Owner WIth a Major Problem! Crank no-start
