Bolts for the 5.4 engine cover
Old Mar 6, 2012 | 08:51 PM
carrottop25's Avatar
what kind and size are the 3 bolts for the 5,4 triton cover that goes over the throttlebody?
missed place mine and would like to put that cover back on
Old Mar 6, 2012 | 09:00 PM
Uncle Jesse's Avatar
I am missing one for my 4.6 as well..
Old Mar 8, 2012 | 08:25 AM
wilderthing's Avatar
If you can't find the size- sorry I can't help you- you could drill out the hole and re-thread it if you have a tap and d set. You could also use cable ties temporarily. This could also be a good excuse to buy a vernier caliper (which could help you in the future as well). some you can find for under $10 for a no-frills basic plastic one.
Hope this helps.
Old Mar 8, 2012 | 08:34 AM
Toyz's Avatar
Just go to the hardware store and look at metric bolts. I couldn't tell you what size they are but I could pick them out if I needed to.
Old Mar 8, 2012 | 09:22 AM
My01SCrew's Avatar
I'm pretty sure they're a 10MM head shouldered bolt. Maybe a half inch to an inch long, I'll look if I still have one in my tool box next time I go out.
Old Mar 12, 2012 | 10:32 PM
Just checked, My 98 is 10MM. I didn't remove the bolt though so I don't have any other dimensions. Sorry. Hope that at least helps you some.
Old Mar 12, 2012 | 10:43 PM
That is for the 4.6-
I assume 5.4 is the same
Old Mar 13, 2012 | 02:47 PM
Halverso_99's Avatar
Bolts are the same for 4.6 and 5.4
Old Nov 13, 2024 | 12:19 PM
Roccotaco's Avatar
Bolts for 5.4 l throttle body shroud
Hi, I just put my shroud back on my 5-4 l 04 expedition. The bolts are M6x1.0 1 and 1/4 in Long. It is a hex flange bolt 8.8 grade. It has an M10 head on it. I hope this helps!
Old Nov 13, 2024 | 04:11 PM
Thread is 12 years old...........
Old Nov 13, 2024 | 06:08 PM
jimbo74's Avatar
5 Year Member
lol
but you can get them at ace hardware in the specialty section, or a junkyard
