Power Steering Problems
I have a 1997 F150 4x4 4.6.....I recently had problems with my steering. It was difficult to steer at low speeds figured pump was bad. Didn't get to it right away. Ended up changing the steering column bearing beacuse they where broke. Also changed the power steering pump out on it as well. Now you can not turn the wheels with the vehicle in park and the tires on the ground. Like the pump is not working wheel doesnt move at all left or right cant turn it hardly will moving. It would turn prior to changing the pump. What are some possible solutions. Tried bleeding it got some air out but now pressure line coming from pump to gear box is leaking. Is there maybe a pressure switch that went bad maybe. Where is this located. Thanks in advace... Zack
