View Full Version : 1997 - 2003 F-150
- Charging battery problem
- 4x4 trucks, Front diff./oil pan clearance after suspension lifted
- No spark issue
- Hyperflash LED turnsignals
- Maybe cat?
- What the Heat??
- No Horn or Cruise after accident.
- 99 f150 4.6l engine noise
- 2003 4.2 oil pan removal
- Lightning Clone Build!
- Need help starting my truck
- 2001 F150 5.4 needs an engine
- Rust or Undercoating
- unknown code
- Dome light wire, driver side kick panel - interior LED install
- No Crank No Start.
- Brake issue
- Trip odometer reset button
- Loss of power
- Engine bogging issue.
- I Need Some Help with Two New Engine Related Noises
- F150 trouble
- code 0161
- 2002 F150 Lariat Supercrew 4x4
- PI Heads or Trick Flow Heads?
- 2001 f150 gauge cluster
- 2001 f150 screw. Transmission
- Do you have long tube headers on your truck?
- Cat. Converter question?
- 2001 Factory Service Manual
- Headers?
- Trying to replace sector shaft seal
- I have 2 questions?
- 97 f150 power window problem
- 2003 ford expedition differential removal
- Need HELP! 2001 F150 XL 4.2 won't crank.
- 2pc or 4 pc headlights?
- 2003 insterment cluster
- 2002 F150 V6 Cylinder Misfire
- squeaky front passenger side wheel
- LF 2003 Screw parts
- '01 F-150 No brake/rear turn signals
- 97 4.2 misfire cylinder 1 and Egr insuffient flow
- Code 171 update
- long tube headers?
- Hi flow questions, please help
- Door rattles when bass hits
- Knock knock....it's NOT a rod!
- 2003 FX4 F150 Center Console swap
- 4.2 Cylinder 3 misfire
- Gotts mod impossible
- Dash vacuum hose busted? Loud noise
- Help prolong the life of my 02 5.4 fx4
- Motor swap coils plz help
- How to adjust timing
- 2001 F150 with bad gas mileage
- Body lift removal
- 97 f150 4.6 2wd questions
- Motor replacement 4.6
- Flareside/styleside bumpers
- Help! F-150 4R70W transmission 98 vs 99
- No signal to start solenoind and tranny codes
- Torque converter rattle?
- Loud rattle
- Dash vacuum leak PLZ HELP
- Does dealership still help
- 2001 f150 led dash lights
- 97 f150 no start after steering column changed
- New powertrain?
- 12 valve Cummins swap
- Rushing Air Sound coming from Brake Pedal???
- Starter spins but engine does not turn over (1997 4.6)
- Help with transfer case
- 2001 harley edition supercrew axle swap?
- Lug nut Dia. and Pitch
- Shudder I'm reverse only.
- Passenger side door wont lock
- body panel Boss >>LAwest conversions
- How do I remove the remote console-mounted CD player from my 2002 SuperCrew?
- How to disable my anti-theft system in my 1999 Ford F-150 and where is it located or
- 97 f150 oil cooler hose housing
- Well, that was interesting.
- The only F-150 I'd leave parked in Philly...
- 01 4.2 hard start and stalling when cold
- timing a 03 2v 5.4
- Help, light issues can't find my dash light wire
- 2003 Ford F150 Heritage Edition - Rear Doors won't open
- Truck shake and sputters
- Engine shakes after replacing plugs and wires
- 4.2l 1998 intake manifold gasket tsb 99-20-7
- FYI for truck not starting despite despite cranking property
- 99 F150 4.2L V6 Automatic not turning over
- Transmission locked up
- 2002 F150 Supercab - rear door wont open.
- 1998 F-150 anniversary Model
- front license plate
- running boards
- 4R70W tranny problem
- 4WD vacuum hose part number
- heater core and plastic hose assembly replacement
- Lift spindles
- 4.6l no spark no fuel help!
- Are Exhaust systems the same between engines/models?
- Side Skirts?
- Water dripping above bell housing
- steering squeek
- Brake issues
- Truck specs
- need help shaking in front in but almost all new parts.
- Clicking Noise Rear
- 99 F150 starting issues
- Slip yoke after trans swap
- Rear driver side truck leans
- Replace CV boot or entire half shaft?
- Engine: rebuild or replace recommendations?
- Vandalized ‘01
- Truck Hesitating when starting from a stop.
- Sorry if this is a dumb question 5.4 engine swap
- Can’t pin point
- Headlights??
- misfire on one and eight
- High idle issue
- Lug Pattern
- P0 0174 Code
- Auto Lamp feature doesn't seem to work
- Inside dome/door lights
- 2002 Supercrew compass problems
- My F150 is Haunted....all of the sudden...then not.
- Unable to rotate engine by hand after valve seals replaced
- 2002 ford f150 cranks but will not start
- 03 XLT Supercab seats... Repair or Replace?
- can't remove rear wiper arm 1998 ford expedition
- seeking some insight
- P0401 egr insufficient flow
- Check Engine Light does not come on
- Steering Wheel Issues
- 2000 f150 rough idle
- 2003 f150 xlt
- 2002 4x4 wont engage. light stays on
- 2002 ford fi150 4.6 l
- Windshield Wipers
- Throttle Position Sensor screws
- Rebuilding my 98 F150
- Replace Original Alternator on 2001 F150?
- AC Compressor
- pushrod 5.0
- new here 2003 F150 4x4 supercrew overheat problem
- Pedals won't adjust
- Help
- Ignition coils
- Flashers
- Hub assembly bolts
- 1997 F-250 5.4 triton shuts off while driving without warning
- Front brakes dragging more as I drive
- Heavier weight oil for high mileage motors?
- Wont start after replacing Neutral position switch
- leakingwater under the intake manifold
- 99 F150 4.2 V6, Coolant mixing in oil pan
- 2002 F150 XLT 4X4 heater hose help please!!
- Fuel line repair
- Code P1298
- Spongy Brake Diagnostic
- Abs
- Still new
- question about 2002 f150 exhaust
- 99 F-150 won't start
- 97 f150 4x4 clunk rattle
- Dead gauges - ran normal - then died on highway
- 2002 f150 no speedometer or odometer
- It was time for new tires
- 99 F150 cranks but won't start
- 97-03 lights dimming, alt and batt are good
- Should I invest in mods?
- Tire sticks out further
- 2000 f150 5.4 noise by pulleys
- Frame Rust problem
- Engine spark knock under load
- Need help with my IAC valve
- 1999 F150 won't start
- 2000 4.6 rwd Transmission Swap Auto-Manual
- 03 F150 Front Stablilizer Base Hole Worn
- P to lt psi conversion
- 1999 4.2 v6 power loss
- New fuel pump, cranks but no still no start
- charging systemfailure
- Valve cover tubes on V6
- Truck Starting Problem
- ABS Codes
- Fiddy + Coyote = Patman
- New key ignition cylinder
- 2000 f150 4.6l
- 2001 F150 supercrew 5.4 overheat
- V10 swap questions
- help with fixing my f150
- F150 4.6l vs mustang GT 4.6l
- Coolant leak 03 Super Crew 4.6
- power windows stopped working
- Help! 98 f150
- 1997 electric shift transfer case sensor ID question
- tail gate interchange
- Replaced heater core now I have low almost no air flow
- Exhaust smoke
- Dash Gauges
- front end same same
- Cruise control
- Drip drip drip went the water
- 2000-2003 f150 body style 3 inch lift
- Not to smart
- cant get my turck to start
- truck acts as if key is turned on when it isn't and the key is out
- Heavy Battery Draw Issue
- 2000 oil and filter
- '03 4.6 4x2 at a good price, now begins the labor of love
- Cranks fine, won't start, second time in two months
- 2003 Supercrew Replacement Keys and Remote
- Towing Dog up hill
- Cylinder 7 misfire
- driver seat replacement suggestions
- loud bang, no crank no start
- 10 psi from shrader valve. 12 psi engine start.
- 99 F150 Cranks but wont Start
- 2002 F150 5.4 Not Starting
- 98 F150 5.4 Temp Gauge does not move
- Wiper issues
- What would you do?
- P0171, P0174 codes
- Wiper/Radio problem???
- Idle when stopped bad shake
- 235 tire width too thin?
- Humming at idle, someone thought it was a vacuum leak??
- A/c and heater not blowing 02 f150
- 03 f150 super crew engine swap with 01 f150
- 97' 4.6 to a 04' 5.4 Swap
- Cylinder 8 Misfire and Unsecured COP
- what year and make of hoods are compatible with 2003 expedition
- Random plug question
- F150 no crank
- Newbie questions
- First it overheated, now it will not crank.
- Instrument cluster and rough idle
- no start no noise at all
- Clanking sound after replacing sarter and flywheel
- Newbie Rear End Questions
- Engine swap question
- Running fine, then today is dead dead.
- Battery Drain coming from the Alternator Field Fuse
- Limp mode under load
- Fuse locations for battery charge system for 1999 ford f150 with no batt charge
- AC/Heating Issues
