Clanking sound after replacing sarter and flywheel
1991 chevy g20 van replaced with new fly wheel and starter after 2 days getting clanking sound when i first start vehicle runs fine only when starting vehicle after sitting a few hours I also own a f150
This applies to any vehicle; was the flywheel bolts torqued to spec?
If automatic trans, was the converter bolts to spec?
Does the starter need a shim?
Is the starter engaging the flywheel properly? Remove the starter and look for signs on the flywheel of interference.
The starter gear may be hitting the flywheel more than just gear/teeth engagement.
One or more of the above has to be the cause.
Good luck.
Good luck.
