Frame Rust problem
Frame Rust problem
I am looking to purchase an older F150. The one I found that I like, the dealer told me had a rust problem with the frame and that they fixed it. Any thoughts on whether this would be a good purchase? The truck is about 7 hours from where I live, so may still drive to take a look at it. It is a 2002 Ford F-150 Supercrew with 93,000. Do these model years have problems with frame rust? I am just worried if the rust or repair may have weakened the frame for towing which I plan on towing a camper with it. I am not familiar with these models or their known issues so just thought I would ask for opinions. Thank you so much in advance for my search for one
I definitely would get it inspected by a competent mechanic if I wasn't qualified to inspect it, before purchasing. You should be able to get them to show you what they repaired and how they repaired it. The radiator support seems to rust quickly. The rear diff cover tends to rust quickly. They can be replaced but the frame needs to be looked at carefully.
