PDA
View Full Version : 1997 - 2003 F-150
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. Replacement headlight lens; glass?
  2. Strange idle
  3. 03 F150 no start. Not fuel pump.
  4. Is there a trick to removing wiper arm from spindle?
  5. Engine Misfire
  6. Need Parts for a 4.6L Triton?
  7. Navigator sun visors in a F-150
  8. 1998 F-150 charcoal canister
  9. New to the forum- complete overhaul needed
  10. Transmission question
  11. Wanting suggestions on what to do to my truck
  12. Ebay Knockoffs FX4 wheels
  13. 2001 F150 SuperCrew Tail & Dash lights
  14. Vacuum line help needed
  15. 97 F150 Rear Brake Shudder - Need Help
  16. what was done to my new old truck today
  17. 2002 F150 7700 will not start!
  18. 97 f150 5.4 auto e4od swap to 99 svt 5.4
  19. Lift, Tire, Wheel, Brand, Size questions, '03 XLT FX4
  20. Temp read out
  21. Frosty
  22. Lighting
  23. 2001 f150 battery light stays on
  24. A Pillar water leak - removing trim?
  25. 1998 f-150 4x4 temp guage
  26. 02 supercrew hop
  27. Adjusting torsion bar
  28. 98 F150 4.2. Computer reset?
  29. 2002 4.2 L No Start Draw on Fuses 15 and 103
  30. Scraping sound during acceleration
  31. 98 4.6 XLT engine replacement underway
  32. Heater problems
  33. 2000 fuel pump
  34. BIG oil leak
  35. 2001 f150 supercrew nerf bars
  36. Parking Brake light - I hope it's not...
  37. 4.6 with 5.4 sct 87 octane tune
  38. '00 XLT - 238K miles and my baby is toast (no, really)
  39. 98 4.6 Running Rough
  40. NO OD light or switch function..
  41. new owner of 1997 needs help with gas tank...
  42. Please help
  43. Plug Insert Loose
  44. gas gauge malfunction
  45. Power Window
  46. 99 f-150 s.o.s.
  47. 98 NASCAR rims on 03 f150?
  48. Need TIME-SERT Kit DFW, TX
  49. 1998 f150 stopped running while driving
  50. Parking Brake Switch
  51. Not getting power
  52. Water in doors
  53. New bumper idea??
  54. Need to know which fuse is for Horn
  55. Looking for New Bumper For 01 Crew
  56. no power
  57. Repair and maintenance costs
  58. battery saver
  59. 2001 F-150: Is something wrong with this shock installation?
  60. Looking for a Part for 2001 FORD Tonneau Cover
  61. 97 power windows stopped working
  62. the day was my truck built
  63. Disconnected airbag
  64. Water comming out of exhaust
  65. rough idle when in gear, smooth when in park
  66. 03 F150 EATC blower works on Aux power, but not when engine is running
  67. Doors rattle
  68. Cleaning throttle body
  69. Steering alignment
  70. Truck idling OK stalls when stopping or going down a steep hill
  71. Mysterious third fuse box under hood
  72. What passenger side front door fits SuperCrew 2003?
  73. Replaced Actuator but still won't unlock door
  74. newbie here, i need a couple answers please
  75. New Shocks
  76. need engine wire harness
  77. Transmission bracket
  78. Getting bad mileage
  79. 4.6 to 5.4 mounting ignition coils
  80. Steering box instructional?
  81. Possible vacuum leak
  82. 1997 F150 4.6 4x4 Not Working
  83. Seat Replacement Options
  84. F150 best cam 5.4
  85. 99' Exhaust donut
  86. 4.6 pi swap or 5.4 swap
  87. Payday tomorrow, broke tomorrow (purchase list)
  88. electrical problems
  89. accelerating problems
  90. Looking for advice
  91. 2001 4.2L v6 running lean on bank 1
  92. Front end rebuild time - question
  93. Odometer light keeps turning off!
  94. install windshield mirror?
  95. '98 F-150 Shakes
  96. 93 octane going back to 87 ?
  97. Vanity lights, map lights, auto mirror no work :(
  98. ignition lock cylinder 2001 f150
  99. 2008 Ford Expedition
  100. Shift Problem?
  101. Steering Gear..
  102. DeathGrip seat belts....
  103. Need help buying headers
  104. rough running 5.4
  105. 1999 all new ac system how much oil and type
  106. Front end leaking grease?
  107. 4.6 timing chains
  108. Nascar truck needs to be lower.
  109. Mustang
  110. 01 Tritan Engine Stumble
  111. Complete Exhaust Upgrade
  112. A/C air speed switch
  113. Glove box installation
  114. Review of denso 673-6000 coil on plugs
  115. temp gauge maxed
  116. 2002 F-150 Gear Swap question
  117. Good 33in Tires
  118. 4.2 hissing sound
  119. Brush bar with body lift
  120. 17 to 16 inch tires - same ride height?
  121. Seat Warmers
  122. 12v powerpoint
  123. Gauge Problem
  124. ABS light
  125. Gas Milage in 01' F150
  126. mounting to engine stand
  127. need help identifying transmission part
  128. my taillights wont come on niether will brake lights
  129. F150 sometimes starts, sometimes doesn't
  130. 2001 won't start until you take out/reinsert key!
  131. 2-4 light thumps, while starting off or breaking at low speeds?
  132. Dip Stick
  133. Speedometer woes -
  134. Lower R ball joint replacement
  135. Headlights turn on when key is turned on
  136. Help with lights
  137. Air conditioning kinda of working
  138. Saying goodbye to my 2003 tomorrow
  139. 2002 f150 supercrew drives poorly when wind blows
  140. Trans problems 97 f150 4x4 4.2
  141. Starter?
  142. 2007 f-150 5.4 3v triton xl radiator flush
  143. New used 01 F150 Lariat ext cab offroad 4x4
  144. 2.5in leveling kit.
  145. silly e-brake release cable
  146. Dodge/GMC/Chevy 16 inch wheels fit 2003 F150?
  147. What controls how far up/down the driver's window moves?
  148. coolant leaking out of strange tube
  149. Don't Know How To Open My Rear Doors
  150. Clutch Bypass
  151. 1997 f150 5.4 ecu swap?
  152. 2002 Rear Seat Back Removal
  153. find spider gear
  154. 17 inch wheels, 2003 5 bolt - will 16 inch fit OK?
  155. Fuel system cleaner
  156. Key would not start truck
  157. Time to look into redoing suspension
  158. Help me I'm 16 just want my truck fixed 2001 supercrew 5.4
  159. Need some help fellas, misfire at startup
  160. Suspension 2001 5.6 XLT
  161. Dragging Vacuum Hose
  162. draining out bad gas
  163. another manual shift 4x4 problem
  164. options to unbolt torque converter from flexplate w/ stuck crankshaft
  165. Best brand for cold air intake for 99 v6 4.2?
  166. What are my wheels made out of?
  167. what to do, what to do....
  168. 02 f150 hubs
  169. Crank no start
  170. 2002 5.4L - 170,000 Miles - Tuneup list..
  171. Rear seatbelt question! Safety issue?
  172. CA or US made?
  173. Anyone know what brand of wheels these are?
  174. Sell value of a non-running '99 F150?
  175. 4x4 question
  176. power lock problem
  177. F150 engine swap and 2wd conversion questions
  178. Clock Spring
  179. Door jamb switch???
  180. Can someone help
  181. No door chime?
  182. #8 misfire
  183. Interior/Exterior Lighting
  184. Bushings (leaf springs)
  185. Hearing directional click on AM radio
  186. Rough Country 3.5 inch spindle lift show off
  187. Looking for a thread
  188. 1997 f150
  189. Truck repeatedly blowing # 30 fuse and stops running
  190. Rough Idle while in gear, surging under heavy acceleration
  191. 2002 F150 4x4 Tires
  192. F150 4.6 5.4 swap
  193. Is this knock sensor count too high?
  194. When to change fuel injectors
  195. Need help, broken ignition actuator rod
  196. 1997 wont turn over
  197. Which spray paint is closest to the Ford red on 2000 F150?
  198. 2002 5.4 without cam Phasers?
  199. has anyone used 1A parts front end kit ??
  200. Murica
  201. MAF diagnosis using BARO PID
  202. About to order a new stereo for my 97, help!
  203. I bought my first 4.6
  204. 99 with airbag issues
  205. 98 f150 speaker problem
  206. Tow mirrors
  207. 01 5.4 whistle at idle
  208. where can I find it headliner shell
  209. Advice on entering the F-150 world and Hello
  210. Cruise control issues after recall work at Ford....
  211. pulled door actuator vacum line from firewall
  212. seeking recommendations on 1998 4.6L Romeo rebuild
  213. Advice RE p0402 diagnostics data
  214. does not want to slow down
  215. Temp Guage rises only at idle??
  216. 98 speedo/vss/trans questions
  217. 2000 wont start
  218. Cluster Light Out
  219. Replacing idler and pitman arm.
  220. 2001 rough idle and evap
  221. 98 f150 4x4 weird problem thinking vacuum
  222. Why do my coils keep exploding?
  223. Specific wheel/tire question
  224. Blows on low only
  225. 1999 F150 what did I buy?
  226. HID headlights
  227. Will 275 70 17 Fit on my 98 f150
  228. 98 After Market Tow Mirrors...Finally!!
  229. Fuel Problem
  230. 6" Zone lift vs 5" Rough Country
  231. Can I figure out wheel stud size from VIN for rotor purchase?
  232. Heated Throttle Body Inlet Hose Leaking
  233. AC not working
  234. overheating
  235. won't come up to temp
  236. towing capacity
  237. No crank no start
  238. P0430 puzzler
  239. wheel question
  240. 97 Romeo 4x4, CHT removal questions..
  241. Help what is this plug for.
  242. Needing Some Advice
  243. Window Wont Roll Up
  244. ABS engages intermittently
  245. Radiator life?
  246. Erratic Idol
  247. Old Threat - Revisited: Propane odor in cab
  248. 99 f150 4x4 to 2
  249. Running rough, power loss
  250. 2003 Rear End Lift
