another manual shift 4x4 problem
Old Jul 26, 2015 | 07:54 PM
cschmelzer's Avatar
1997 ford f250 4.6 manual shift for 4x4, automatic transmission
so today I engaged my 4x4 and it did not engage. I put the truck on the lift and tested a few things
1) I put the truck in 4x4 and the transfer case engaged
2) I checked #23 fuse and its good
3) if I manually engage the lever on the diff the front wheels will spin in 4x4
4) one thing I have noticed is when I check for power at the solenoids both have power. when I swap the test light to the positive and check the ground on the disengage solenoid the light turns on regardless if the truck is in 2wd or 4wd. the light does not turn off when I engage 4wd. when I check the engagement solenoid the ground is barely lit on the test light like its receiving half of the power. and it stays on regardless if I am in 2wd or 4wd. I believe I have a bad GEM what do you think?
5) I believe the problem is in the GEM and it is not swapping the grounds to activate the vacuum solenoids.
I believe the gem is keeping the grounds activated
I have also watched he diagnosis video
I searched the forum and followed this
How to Troubleshoot and Fix F150 4X4 1997-2003
________________________________________
I am posting this because it took me AGES to find this information and peice it together from many sources all over the internet. From a girl who knew NOTHING about these systems a few weeks ago - here is a quick and easy guide to troubleshooting your 4X4 problems -- mostly for Manual shift on the floor (MSOF) systems or what goes on mechanically after you press the button on the electronic systems. All you need for these tests is a friend, and a socket set.
The 4X4 works with two systems - the shifter on the floor manually engages the transfer case. It also causes a relay to ground one of two solenoids that cause vacuum lines to activate an actuator which engages the front differential. If either of these do not work, your 4X4 won't work.
In my case, ad most that I have read, the 4X4 simply does not engage and the dash light either always goes on or does not go on.
1. Rule out transfer case problems: This is easy - get someone to put your truck in 4X4 and roll forward while you peek underneath from the side. If the front drive shaft is turning, your transfer case is fine and engaged.
2. Check the fuse! #23 by the hood lever and parking brake under the front dash.
3. Check the functioning of the solenoids: this is easy as well. The solenoids are located in the passenger side of the engine compartment directly behind the battery on the firewall.
From what I have read, a good indication of a problem here is the absence of the dash light. You can get fancy and test them electrically (they should each have 12V power all of the time) but the easiest way is to put your fingers on the plastic caps and feel and listen for a click as someone shifts your truck in and out of 4X4. If they click - they are working! If not, this is likely your problem. It is a common problem apparently for these years of trucks to get water in the solenoids which then freezes and cracks them.
Here is some good info and part numbers if this is your problem
"The right solenoid (E8AE-9H465-AA) controls the vacuum to the return side of axle engagement diaphragm. The left solenoid (E8AE-9H465-BA) controls the vacuum to the activation side of the axle engagement diaphragm. Ford has been having chronic problems with water entry into these solenoids, corroding them from the inside and seizing them, as you've seen!<o ></o >
They've been redesigned and those old part numbers (E8AE-9H465-AA/BA) have been superseded.
The latest designs are listed as:
Disengage solenoid 6L3Z-9H465-A (identified by electrical connector rib at 9:00 position)
Engage solenoid 6L3Z-9H465-B (connector rib at 6:00 position).
3. Check your vacuum lines: This is a little tricky to do because they wind their way from the solenoids all the way to the 4WD actuator on the front axle. One hose leaves from each solenoid at the front (close side to the battery) and one is pink and the other is blue(greenish if older). Follow the lines down as best as you can, checking for spots with wear or rubbing. Also make note if they seem old and brittle as there could be a crack you don't see. Mine were rubbing a bit on the passenger’s side wheel well so check there. Now crawl under the truck and in the center on the axle is the actuator diaphragm. It is under a cover that is easily removed with a socket and the two hoses are attached to it. Pull the hoses off and while the truck is on, and someone shifts it in and out, put a finger over the end of each hose. The vacuum should alternate hoses when shifted and the pressure should be equal although it is surprisingly not a strong pull. If your hoses look good and suck like I said, they should be all good (this also confirms that your solenoids and vacuum reservoir are working as well.)
4. Vacuum actuator function: This is easy to check. Crawl under your truck, take off the cover for the actuator and watch as your friend shifts from 4X4 and back. When the truck is shifted to 4X4, the shaft should slide into the diaphragm, moving the lever it is connected to to the passenger side direction. When shifted back to 2 wheel, the shaft should slide out of the diaphragm towards the driver’s side. The movement is about 2 inches total and happens smoothly.
If this works, then you may want to check to see if the shift fork (the lever that the actuator moves) is not bent or broken, or the pin that holds it in place is not sheared. It this all good, then maybe your front differential needs help?If the diaphragm moves stiff and short, it is one of two problems: there is a tear in the diaphragm or the shaft has corroded and is stiff and needs lube. To check if the diaphragm is just stiff, assist the truck by pushing the shaft in an out by hand. This should engage and disengage the 4X4. When I did this, I engaged the 4X by pushing the shaft in but it was very stiff and hand to pull it out again with leverage from a screwdriver. Mine was just stiff and needed lubrication - which worked! If you can move it freely by hand, I would say there is a tear in the diaphragm and you probably need a new one. Try ebay -- they are $100 where at Ford they are $460!! Part number is F65Z-3G360-BA
Old Jul 26, 2015 | 09:20 PM
Bluegrass's Avatar
The firewall solenoid is supplied ground from the Gem 'through' the case motor circuit board.
Be sure the case motor board contacts are good before you change the GEM.
Supply a ground to the solenoid from the case motor appearance before and after the case motor to see what condition you have.
If the Actuator functions after the case motor toward the solenoid, the ground is not getting through the case motor board..
Good luck.
Old Jul 27, 2015 | 03:20 PM
cschmelzer's Avatar
When you say firewall solenoid do you mean the engage/disengage solenoid if not where is the firewall solenoid
Where is the case motor circuit board
And what actuator are you referring too
Ive serached all over the form and cannot find the location of these
Old Jul 27, 2015 | 04:13 PM
Bluegrass's Avatar
The video photo shown is of the firewall solenoids.
The case motor board is attached to the motor.
You will need to remove the motor to check it out.
The actuator is located on driver side up against the center section output drive to the left wheel.
It has two vacuum hoses attached.
This device moves a sliding lock collar to connect the differential to the CV axle.
Checking circuit continuity for an open is key to recognizing where and what the cause is of no engagement.
Once the firewall solenoid operates it tells the GEM to light the 4wd lamp on the dash.
This is a form of self test but it cannot tell if the vacuum actuator has operated because there is no electrical monitor for that action.
Good luck.
Old Jul 27, 2015 | 04:28 PM
cschmelzer's Avatar
Im still confused on the case motor board and its exact location.
So it is attached to the engine itself or to the transfer case ort he diff.
And thea actuator is the vacuum actuator that is attached to the diff witht the 2 vacuum lines?
I really appreciate all your help
So to clear things up when i activate the manual shft 4x4 and slide it into 4hi. It goes to the case motor board then to the gem then to the firewall solenoids swapping them and activating the activation side causing a change in vacuum sliding the actuator and locking the diff?
Old Jul 27, 2015 | 04:55 PM
cschmelzer's Avatar
I thought the "case motor" was on the transfer case and to top it off only on trucks with the shift on the fly feature
My truck has the manual shift for the 4x4
Old Jul 27, 2015 | 05:26 PM
There is a case motor no matter whether you have a dash switch or floor lever.
Old Jul 28, 2015 | 02:13 AM
Bluegrass's Avatar
STOP! you have a mind set your not getting over.
I told you the circuit board was part of the case motor and you would have to remove the motor to check it out...did I not?
Re--set: thinking.
When you move the floor shift to 4H or 4L you are 'requesting' the GEM to operate the case motor to it's first position (4h) and engage the transmission to the transfer case drive. You have indicated that is happening and not an issue.
When this happens the case motor 'board contacts' closes through a ground to the firewall solenoid. The solenoid operates allowing engine vacuum to go to the Actuator to pull the locking sleeve in and lock the left front axle.
The firewall solenoid 'signals back' through the case motor on a separate lead to the GEM to light the dash lamp telling you the chain of events has completed.
I also told you there is no way to know if the Actuator has operated except by observation or driving circumstance because it is a mechanical action only.
For 4L operation the front actuator is already operated and setup so there will be no change in that status.
However, the case motor is requested to go to it's second position, engage gear reduction drive train and... signal the 'PCM' to 'change' the shift schedule to match the low gearing.
Moving the floor shift back reverses all these actions.
Trouble:
Either the case motor 'board contacts' are faulty, a harness lead is open, a vacuum hose is faulty or the Actuator is frozen or faulty.
The Gem seldom ever fails because all it does is supply a ground to operate the firewall solenoid.
There are no other fuses involved.
You have to see the forward moving chain of events, the signal feed forward and return conformation the system offers to light the dash lamps..
Whatsa a morr can I tell you? Co-pecsh!
Good luck.
Old Jul 28, 2015 | 05:31 PM
cschmelzer's Avatar
Guys i really appreciate all of the help
But i have 1 question. I have searched the forum like crazy and i have reread post after post
postyou stated the circuit board is apart of the case motor.
Where is the case motor at on the vehicle???? I have lookes at the transfer case the engine bat the front diff and i cannot find ot!!
Old Jul 28, 2015 | 06:47 PM
kd4gij's Avatar
Google is your friend.
https://www.google.com/search?q=2000...aaaL01YwjO8%3D
Old Jul 28, 2015 | 06:56 PM
Bluegrass's Avatar
On the ear of the transmission.
Find electrical connector and bolts that hold it on.
It turns a control rod in the case to engage the gears as well as rotates a contactor to close electrical contacts in the board leading out to the Gem and front solenoids via the muti lead harness you disconnect.
Good luck.
Old Jul 28, 2015 | 08:38 PM
cschmelzer's Avatar
cschmelzer's Avatar
is that it (circled in red)
Old Jul 28, 2015 | 08:44 PM
cschmelzer's Avatar
I have searched everywhere from google to the forums and from what I see there should be a motor there.
just for reference this is a 97 f250. (basically a (7700) f150)
Old Jul 28, 2015 | 09:12 PM
Bluegrass's Avatar
I don't know how your computer works but when I type in TRANSFER CASE MOTOR, FORD F150, on mine all kinds of info and photos come up.
Your photo is not what is on most F150s.
Good luck.
