Is there a trick to removing wiper arm from spindle?
Old Dec 5, 2015 | 06:01 PM
Dennis Albert's Avatar
Question Is there a trick to removing wiper arm from spindle?
I have been trying to remover drivers side wiper arm from 98 f150 Lariat but it will not budge. I sprayed Blaster on it and tried prying and using a gear puller but it won't move. Was trying to use a couple of screw drivers to pry it off but afraid that I was going to break the plastic on the shroud, any ideas?
Old Dec 5, 2015 | 07:33 PM
slightly push down on the arm side to relieve spring tension on the bottom of it. While pulling up in a swift motion
