Glove box installation
Old Aug 31, 2015 | 11:40 AM
Tat2ski's Avatar
I had to remove the glove box on my '98 Ford F-150, and need to reinstall it.
Is there a trick or a method to attach it to the dash because the spring loaded hinge is very difficult to pry open while hand feeding the screws in the dash. Has anyone done this before? I took it off to repair my blend door, and now wish I never removed it.
Old Sep 1, 2015 | 07:46 PM
Zilla98's Avatar
I still haven't put mine back in after doing heater core / blend door as well. Stubborn little thing it is.
Old Apr 6, 2019 | 01:32 AM
matt fowler's Avatar
Install tip
I own a 2001 crew cab but I doubt the glovebox is different. What I did was remove the front cover and the box itself so all I had left was the hinge and the metal base. I was surprised that it A. Weighted so much, and B. Made of metal.
So what I did was hooked it to the two prongs that it sets on and slowly pulled it down, separating the hinges and cover to get to the screw holes. Hadvto do this several times but was finally able to get the one closest to the door started and then got the other two.
Took time ans some patients but this is your only hope without going crazy.
Best of luck.
Old Apr 6, 2019 | 10:19 AM
I hope that this is fixed by now - 4 years later.
