Not getting power
Old Oct 31, 2015 | 03:32 PM
Kim1223's Avatar
Not getting power
I have a 2000 ford f-250 with a 5.4, Its rolling over but not starting, I have no power to the cranksensor, cam sensors or coils, fuel pump also not working. Any Ideas?
Old Oct 31, 2015 | 05:21 PM
Bluegrass's Avatar
You have a power failure to the PCM.
Check the PCM Relay seating, the Relay and the fuse feeding it.
Good luck.
Old Nov 1, 2015 | 02:24 PM
Did you check to see if the fuel cut off switch has been activated?
Old Nov 1, 2015 | 06:30 PM
projectSHO89's Avatar
The inertia switch cannot prevent power from getting to the coils. Look upstream as Bluegrass recommended.
