Repair and maintenance costs
I have a 2002 Supercab and it has 135,000 miles on it. Recently, I have had to replace the front lower control arm ball joints, bearing hubs, all 4 tie rod ends, idler arm, sway bar end link bushings, right rear axle and bearing/seal, all 5 flexible brake hoses, all 4 calipers, master cylinder, and replaced the cables that unlatch the rear doors. Still to repair are the overhead console, usually a bad resistor or solder joint, the odometer going black (supposed to be a bad solder joint), the power mirror switch, the blower motor has started making a noise on the highest speed, and the AC has been leaking for a while and now won't hold refrigerant for more than a few weeks. I think it needs a new compressor. I plan to keep it and keep on repairing because I am driving it only about 3k miles/year now since I retired.
Front end and suspension work is easy as any vehicle. Under the hood, spark plug replacements are a bear because they are hard to get to. But, aren't needed but every 100k miles. It's easy to pull the rear axles to replace axle bearings. Special tools are needed to pull the bearing and replace the bearing but many auto parts stores loan tools with a refundable deposit.
Last year I probably spent 5 grand on full front end rebuild, new a/c compressor and lines, and a starter that failed 1200 miles from home [got it towed to the dealer for that one], and tires. Since then, oil changes and gas. 182,000 and going strong.
From what I've seen, the OEM parts start to fail past 120k mark, so be wary of trucks with neglected maintenance, because they can take a dump on you all at once.
At 200k, my truck is very reliable, and I only do oil changes, but admittedly, the truck was expensive to run between 140k and 180k, because all the wear items needed replacement.
I know on my '99, we just replaced the normal wear parts, shocks, tires, plugs, filters, brakes, etc. At 110k it really needed nothing. It drove fine other than that. My starter did go, but never left me stranded because it has a manual and I pushed the truck and popped the clutch.
My '07 has not needed anything. Not even brakes at 60k. Just the usual items. However, being it is getting up in age, I am planning on getting a whole slew of new things on it... shocks, brakes, calipers, hoses, etc. Just to keep it reliable. Still nothing wrong with it, but just keeping up good service on it. Lucky for me, I still got the Ford ESP on it, but they don't cover the stuff I am replacing (except for the calipers). I just want fancier calipers with my new brake kit I bought.
Very reliable trucks.... very reliable.
